Previous in Forum: Internal Combustion engine   Next in Forum: Baseband and Broadband
Statically Indeterminate Structure by Superposition
01/23/2009 1:57 PM
Hello, can you guys please help me with this structure. I have been trying for hours but I cant get it right. I am supossed to calculate to moment at A.
I don't want you to do the work for me, but can you please tell me what may be good to do?`, what is best to choose as the redundant force, and what deformation are important to consider then.
http://img91.imageshack.us/my.php?image=staticallyindeterminatemn1.png
Good Answers: 18
Re: statically indeterminate structure by superposition
01/23/2009 3:35 PM
Hint: Suppose the uniform load was horizontal. What would the moment be at "A?"
Good Answers: 74
01/23/2009 7:12 PM
You would, of course need the length of the vertical member in order to calculate the moment at A. The structure is indeterminate to the first degree.
One way is to make the structure determinate by removing the roller support (call that point B), then solve for ΔB, the deflection at point B. Calculate the deflection at point B under a unit horizontal force at B. What horizontal force is needed at B to restore point B back to its original position?
Another way is to make the structure determinate by changing the fixed support at A to a hinged support. Solve for ΘA (rotation at A) for the applied loading. Solve for ΘA for a unit moment at A. What moment is needed at point A to restore it to zero rotation?
Since the title of your thread includes the words "by superposition", you should consider the horizontal and vertical components of the sloping applied loading separately and simply add the effects of each. Be sure to keep track of the algebraic signs as you do this.
Bruce
Good Answers: 74
Re: Statically Indeterminate Structure by Superposition
01/24/2009 12:00 PM
A third method is to consider the moment at the crank point (point C) to be redundant. Make the structure determinate by adding a hinge at point C and leaving the other supports as they are, i.e. fixed support at A and roller support at B. Solve for all of the reactions and MA (moment at A) for the determinate structure.
Calculate the rotation of each member meeting at point C by standard methods and from that, the angle change at point C (the difference between the two rotations). Place a unit moment in opposing directions on each member (watch the signs) and calculate the resulting angle change. Determine MC to make the angle change zero, then modify MA accordingly.
I think this is the method a practicing engineer would prefer because the determinate structure resembles the indeterminate structure more closely than the other two methods.
Bruce
