Previous in Forum: auto cad   Next in Forum: Bridge Structural Failure Warning: I-10 Lake Charles, Louisiana
What is the best testing method for sewer lines?
01/21/2009 6:26 AM
We have this work for a new building, and were laying our sewerlines, as per specs, the final test should be by smoke test or peppermint test. What I am familiar with is the flood test, could you elaborate on the difference in the methodology between the three methods and which do you suggest what is the best method.
Re: What is the best testing method for sewer lines?
01/22/2009 11:27 AM
Hmm, never heard of using a smoke test or peppermint test for a installed sewer line. These are typical tesats for breathing apparatus fit testing, but they depend on the ability of the apparatus user to detect the odor of the smoke/peppermint intruding through the seal. Sewer lines are sometimes in locations that do not allow proximity to smell for a release. All the municipal sewer lines we test are done with static water or air under a standing head of pressure. If there is a loss of head beyond the acceptable limits there is a leak that must be isolated and identified. I guess you could pressurize the smoke and conduct it like pneumatic air test of the lines. Then the smoke being releasd could be used to locate the leak more easily on visual inspections, once you observed an excesssive drop in the pressure head.
Engineering Fields - Piping Design Engineering - New Member
05/21/2009 11:17 PM
what type of line is it? what is the method of jointing and what depth are you laying at... typically the smoke test are used to find leaks in main lines. the smoke being smaller then a water droplet tends to find smaller leaks around ring joints, and truncations into the main spigots better then your water hydrostatic test. remember a small leak could take ages before you notice the decrease in level.
