Previous in Forum: power generation   Next in Forum: Material Properties at Elevated Temperatures
pipe specs
01/21/2009 11:52 AM
Hi,
Could you tell me the differences in the pipe specs asme B16 to asme B31.
Good Answers: 61
Re: pipe specs
01/21/2009 1:27 PM
The ASME B16 series documents are standards. The ASME B31 series are Codes.
See below for examples:
ASME/ANSI B16.5 - 1996 - Pipe Flanges and Flanged Fittings
The ASME B16.5 - 1996 Pipe Flanges and Flange Fittings standard covers pressure-temperature ratings, materials, dimensions, tolerances, marking, testing, and methods of designating openings for pipe flanges and flanged fittings.
The standard includes flanges with rating class designations 150, 300, 400, 600, 900, 1500, and 2500 in sizes NPS 1/2 through NPS 24, with requirements given in both metric and U.S units. The Standard is limited to flanges and flanged fittings made from cast or forged materials, and blind flanges and certain reducing flanges made from cast, forged, or plate materials. Also included in this Standard are requirements and recommendations regarding flange bolting, flange gaskets, and flange joints.
ASME B 31.3
ISBN #: 0791830403
Published: 2006
Product Type: Print-Book
The B31.3 Code contains requirements for piping typically found in petroleum refineries; chemical, pharmaceutical, textile, paper, semiconductor, and cryogenic plants; and related processing plants and terminals. This code prescribes requirements for materials and components, design, fabrication, assembly, erection, examination, inspection, and testing of piping. This Code applies to piping for all fluids including: (1) raw, intermediate, and finished chemicals; (2) petroleum products; (3) gas, steam, air and water; (4) fluidized solids; (5) refrigerants; and (6) cryogenic fluids. Also included is piping which interconnects pieces or stages within a packaged equipment assembly.
Do it once and do it right
Re: pipe specs
01/21/2009 4:59 PM
Register to Reply 3 comments
