Previous in Forum: pipe specs   Next in Forum: Different types of LPG dryer
15 comments
Material Properties at Elevated Temperatures
01/21/2009 12:14 PM
Where would be the best place to look for the changes in the yield strength and ultimate tensile strength of low carbon steel at high temperature? I am mainly working with 1008 and an operating temp of 1250°F in a non-critical application and I can't seem to find any material specific information. The Machinery's Handbook says for structural steel to use 28% of the strengh at 70°F for use at 1100°F but I was hopeing for more specific data to back this up. A point in the right direction may be more helpful that the answer for only 1008. Thanks in advance.
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
Re: Material Properties at Elevated Temperatures
01/21/2009 12:19 PM
If the material is made to a specification, usually the spec. has that sort of information. For instance a AMS or etc. type spec.
I am guessing your material is not per a spec. or you would already know that?
01/21/2009 2:06 PM
The best source for that information is ASME Section II - Part D
(however, without running through it - I doubt you will find that exact steel in there)
01/21/2009 3:43 PM
Would the ASTM standards have more comprehensive material data not used in pressure vessels? I don't have the budget to justify buying the ASME standards for this non-critical application (exhaust components) especially if they don't address the materials I am using. I have also talked to my supplier and was referred to a mill metallurgist who passed the buck on to a professor that won't return my calls or e-mails (go figure).
01/21/2009 4:00 PM
I can check quite a few references including the ASTM standards (when I get home in a few hours) -
Can you confirm the exact specification?:
AMS 5110 , AMS 5110B , ASTM A29 , ASTM A510 , ASTM A576 , ASTM A682 , FED QQ-S-700 (1080) , MIL SPEC MIL-S-16974 , SAE J403 , SAE J412 , SAE J414 , UNS G10800
01/21/2009 4:18 PM
Thinking a little more here, because I doubt even the ASTM standard will give strengths at temperature -
Find and download for free the MMPDS-01 "Metallic Materials Properties Development and Standardization". It is a fairly authoritative/exhaustive reference.
Look at the graph on page 2-27 and see if that suits your needs (Note the comment on Strength at temperature exposure up to 1/2 hr - without digging more there should be discussion on the creep strength)
Good Answers: 103
01/21/2009 9:12 PM
MMPDS 01 is withdrawn however I could get a link on site
http://www.apesolutions.com/spd/public/.
for down load you can check up the properties on Chapter-2 pages 2-25 to 2-30
01/21/2009 11:13 PM
1. First, define your operating conditions more completely. In particular, how long a time at 1250 F, what load or stress, is the load constant or cyclic, and is the service atmosphere oxidizing, reducing, or neutral?
2. Your choice of steel is seldom used at temperatures above 200-300F for appreciable times. Once you've completed step 1, come back and I think that I can point you in the direction of useful information. Rmember, asking the "right" question will materially aid you in finding a "right" answer.
01/22/2009 3:57 PM
I understand that the material is not ideal for the situation and that there are all sorts of issues when using it above 30% of the melting temperature but I am in a situation where it is all I have to work with.
The time at temperature will vary from 1 hour or less up a max of about 24 hours. This is for exhaust components so the service atmosphere will be exhaust gases (diesel, natural gas, or gasoline) and will cycle from full temperature back to ambient many times.
The load is minimal with respect to the strength at room temperature but there will substantial vibrations to the system.
Good Answers: 68
01/22/2009 9:14 PM
Hello ZAC,
You have given extra info on the uses like vibration and for use in up to 24 hours. You also say it is not ideal for the situation. But, what would be ideal and why can you not use it? Is it the word 'money' and 'cost'?
If that was not a criteria what would you use that you know is suited to the use you want it for?
Can you say what thickness you use? Does this steel you are using fail at welds or pipe length seems? What is its expected life?
Take care................
Good Answers: 68
01/22/2009 10:11 PM
Hello sb,
Sorry I am on and off the computer. Were you taying something to me? IPR? Inter personal relations? We will have to stop meeting like this! LOL!
Good Answers: 103
01/23/2009 3:08 AM
The taking care (I still don't understand as I said earlier and this may have violation of our personal relation - that is what mother bear should say )
But here I meant Intellectual Property Right (assuming you have patented or atleast applied for the patent of the phrase)
Good Answers: 68
01/23/2009 4:18 AM
Hello sb,
thank for the reply daddy bear!.........I have not registered for IRP other than as a user name.
I am not sure if you are pulling my leg here?
Good Answers: 103
01/23/2009 11:07 AM
In case you have send me a mail, I have a problem, My office PC- firewall blocks mu messages and hence can not recieve the mail links, can get direct mails of course.
I get IWSS Security event - blah blah blah - administration defined.
Tried a lot with our administrator, but they are unable to do anything (I am getting a lot of problems like this
Software is like this, can not do anything , it is in SAP, nothing can be done and things like that
Good Answers: 68
01/23/2009 12:54 PM
Hello sb,
hope you are well?...................So can you read posts and PMs on CR4?
Bit of a pain really isn't it?
Sorry.
02/10/2009 8:34 AM
Just for a little bit of a conclusion to this I have found the information in the Key to Steels Database. It is a bit expensive but it has the information I was looking for and then some. Thank you all for your help.
Register to Reply 15 comments
Anonymous Poster (3); babybear (4); E.Dalder (1); JCase (1); sb (3); ZAC (3)
