Previous in Forum: Mechanical Seals - Face Flatness   Next in Forum: astm d2310
9 comments
Wall Thickness for Stainless Steel Pipes
01/22/2009 5:55 AM
How can I know the wall thickness for Sch 60S - SS Pipe ( 16").
However, in ASME B36.19, wall thickness is given for 5S, 10S, 40S &
80S.
Thanks
Be simple and specific for a great success in Life
Re: Wall Thickness for Stainless Steel Pipes
01/22/2009 8:39 AM
google: wall thickness for Sch 60S - SS Pipe
Results 1 - 10 of about 3,420 for wall thickness for Sch 60S - SS Pipe. (0.25 seconds)
http://en.wikipedia.org/wiki/Nominal_Pipe_Size
01/22/2009 9:53 AM
B36.19M is an alternate standard for stainless steel pipe and does not recognize SCH 60S.
If you want other wall thicknesses - drop the 'S' designation and order stainless pipe in accordance with B36.10M
01/22/2009 10:25 AM
Digging a little more ............
It seems you are out of luck, that is, it seems you are looking for a wall thickness of between 0.5" and 0.375"
B36.19M -
  • Sch 80S = 0.500"
  • Sch 40S = 0.375"
B36.10M -
  • Sch 40 (XS) = 0.500"
  • STD (Sch 30) = 0.375"
I don't know the reason why you are looking for a wall thickness in between those designations. But, if it is to save money on less material - I doubt that will happen - you will need a custom mill run of pipe, with a minimum order, and that will not be cheap!!!!
My advice is to bite the bullet and go with 0.500" wall thickness.
01/23/2009 9:59 AM
Diameter of the pipe has an influence on the wall thickness.
2" Standard Black Pipe, Regardless of it being mild steel or stainless steel is approximately 1/8" or .125" for SCH40, and 1/4" or .25" for SCH 80. Whereas on a 5" pipe SCH 40 is about 3/16" thick.
Also note that Pipe wall thickness has a more lax tolerance range then if you were talking about round tube, which is more on the money on their specific dimensions.
01/23/2009 4:01 PM
Yes, you are correct - I should have noted that those thickness dimensions were specifically for 16" NPS
01/22/2009 10:37 PM
I think he was using B36.10M as a reference - not a requirement.?
01/22/2009 11:11 PM
... you could measure it, or have your source for the pipe specify the dimension.
16" Schedule 60 has a wall thickness of 0.656"
Since stainless steel pipe is commonly available in steel designation, I bet this is what you have.... SS pipe 16" sch 60 (not 60S)
01/23/2009 9:32 AM
As per ANSi, 16" sch 60 should read at 0.656".
01/27/2009 5:35 AM
16" sch 60 is 0.656" is from ANSI B36.10 & not as per 36.10.
Thanks
Register to Reply 9 comments
Anonymous Poster (4); Janissaries (1); sachin_rastogi_in (1); SM Steel (1); TexasCharley (2)
You might be interested in: Thickness Gages, Heat Pipes, Flue and Chimney Systems
