How much should we taken into consideration for corrosion allowance for steam pipe with 4bar pressure and 130 degrees in centigrade?How many years are valid for the mentioned corrosion allowance?
First of all,a minimum required thickness should be determined in subject service condition based on code.
Once minimum required thickness is determined, a corrosion allownce can get follow up the life cycle costing calculation, which per your company's policy.
