I forgot my password.
Don't have an account?
Hi all , i want design of (25KVA ) grounding network .
Hi Guest
Start designing. What is the problem. Get hold of a copy of relevant standard depending on the country where you want to design. We pray for your successes and wish best of luck.
Regards.
hi, i was mean that (25 KVA )grounding network for single phase 220v for building has ten room . with my thanks & respect.
Guest quote "hi, i was mean that (25 KVA )grounding network for single phase 220v for building has ten room . with my thanks & respect."
I believe your terminology is incorrect. It sounds like you are wiring a building and want a grounding conductor with the circuits. "Is this correct?
yes, of course.
You need to check the local code requirements. You may need only a ground rod and a roll of #12 romex wire with ground.
I want in details .
http://images.google.com/imgres?imgurl=http://www.istockphoto.com/file_thumbview_approve/5421451/2/istockphoto_5421451-home-improvement-9-romex-14awg-wire.jpg&imgrefurl=http://www.istockphoto.com/file_closeup/object/5421451-home-improvement-9-romex-14awg-wire.php%3Fid%3D5421451&usg=__iK6IdflvAz0ns8tI2syAmQrs5HI=&h=380&w=252&sz=34&hl=en&start=9&sig2=5E9MqEp1ccZ4RjpfcvrZnA&um=1&tbnid=lI9OOTVu3Roz0M:&tbnh=123&tbnw=82&ei=vEp7SZSZJZbGtgfP5cnDDg&prev=/images%3Fq%3Dromex%2Bwire%2Bpics%26um%3D1%26hl%3Den%26rlz%3D1T4GGLL_en%26sa%3DX
