Previous in Forum: ISO TS 16949   Next in Forum: RoHS
Thermal Break Shear Test
01/22/2009 2:48 PM
Any one dealing with fenestration,
I have a requirement to implement a shear test on parts used in Thermalbrake fenestration i.e. 2 peices of plastic swedged in between 2 extruded aluminum frames used in manufacturing a windows. The holding force of the plastic to aluminum is 400 lbs. After some research I have found others who have had similar questions but have not been succesful in determing how they would specificaly perfrom the test. The material recieved is stock pieces of the aluminum with the plastic thermal break insterted and crimped. Question to any one is " how would you go about performing a shear test on these types of units".
Thanks for any response
If you die in the south - going up or down - you have to go through Atlanta - and there will be a layover.
Pathfinder Tags: Shear test thermal break
Good Answers: 266
Re: Thermal break shear test
01/22/2009 4:52 PM
Is what you are testing for the forces in which the plastic would shear or with shear forces will the crimp hold?
In making a thermal brake the plastic is in between the inner and outer aluminum of the frame. In the tests on windows that I have seen your thermal brake would be more subject to pull then to shear. As pressure fluctuates from the interior to the exterior of the structure.
As far as a test build a window and put it on a test wall to see if your crimp holds.
01/27/2009 10:25 AM
You are correct sir - It is a Pull test not a shear test. Thanks for the response. I will get with the supplier regarding size of test sample. This is an item about 2X2 inch square. e.g. A single piece of Insulbar plastic crimped on both edges into aluminum. Each crimp is rated at 400 lbs. e.g 800 lbs for 2 struts.
Thanks
Re: Thermal Break Shear Test
01/22/2009 6:47 PM
With reference to people, the word defenestration refers to being thrown from a window.
Register to Reply 3 comments
lyn (1); ozzb (1); tom@windoor (1)
