Previous in Forum: English Version of Chinese Standard GB50322-2001   Next in Forum: computer applications in civil engineering
Trimix Flooring
01/22/2009 6:29 PM
what is the meaning of trimix flooring in the construction field ? why we r using this flooring ? what is the recommendation for this flooring ? where this flooring we can use ?
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: flooring
01/23/2009 8:47 AM
Trimix isn't a floor surface. Rather, it's a chemical that is applied to concrete walls and floor to prevent moisture. Typically, it's used in flooring under hardwood or laminate to protect moisture sensitive materials. Hope this helps.
Moose
P.S. Hope you'll register with CR4 and become a member. It's free and easy to do.
Re: Trimix Flooring
01/24/2009 9:37 AM
well you can use this flooring any ware hall way kechens It is every duribol and ok nice and cost money for more info go to googl surch and find what ( trimix ) mean thean look on googie for goremen under wood
You might be interested in: Flooring Materials, Magnetic Field Sensors
