Previous in Forum: Can I Use a Washing Machine Motor as an Alternator?   Next in Forum: Meggar Test
Sustaion Earthing resistance
01/23/2009 3:17 AM
Dear sir
1) what is minimum Earth resistance need to maitain for indivisual
Plate eathing or Pipe Earthing in substation
2) We are using 66kv/11KV, 25/35MVA, Star/Delta transformer but we are using solid Earthing(Plate) on star(HV) side, but know our customer asking indivisual Eartpit resistance shall be with in one ohm.
Re: Sustaion Earthing resistance
01/23/2009 12:37 PM
For 66/11KV sub station, yes, earth resistance shall be maintained (practically) within 2 ohm. If you are able to achiev within ONE ohm is very good. You can achiev this by following methods
  • Use CI pipe earthing or
  • Connect more no of GI / Copper earth pits( Plate or pipe earthing) in series or
  • Crerate more earth mats with 50x10 sqmm Copper flat
  • By chemical earthing if your natural earth resistance is more
  • Use bentonite clay to increase the erth resistance by increasing water retntion
  • Mainly check tightness and increase the area of contact
Let Noble Thoughts Comes to Us From All The Sides
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
01/24/2009 5:12 AM
Most substations, I have built, had to be < 1 ohm. As the other fellow said, series of grd rods or a deep well, we used a deep well with a series of grd rods. Its not so much as the star connection, but the fault current and the lightning protection.
Could be worse, it could be me. :)
08/24/2011 1:58 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
01/24/2009 5:38 AM
The old criterion used to be <1ohm to combine HV/LV earths....but the KEY issue is the magnitude of the 'fault current' that the earth system will need to handle safely.
Newer regulations are steering away from the 1 ohm rule and more towards using modelling software such as CDEGS to 'prove' the safety of your design/install by modelling the EPR (earth potn rise).
Go to http://www.sestech.com/ for details of the s.ware and/or www.ees-group.co.uk for more info.
electricaleng (1); mayt2u (1); user-deleted-1092 (1); vinukumar (1)
