Previous in Forum: Window Condensation Cures?   Next in Forum: Pipes vs. Couplings
Pull Force Test
01/23/2009 9:24 AM
Hi, I need to know what sould I use as a standard Pull Force Test for our crimp department. I see there is a a lot of different between IPC Standard and UL486A. Please I really need your help. Thanks
United States - Member - NE, USA Hobbies - Target Shooting - New Member Engineering Fields - Aerospace Engineering - Engineering Fields - Electromechanical Engineering - New Member
Re: Pull Force Test
01/23/2009 9:46 AM
Choose the pull force ft/lbs, direction, and method that best matches the application of your product in the field.
Good Answers: 18
Re: Pull Force Test
01/23/2009 3:52 PM
Use the more stringent test.
Good Answers: 15
Re: Pull Force Test
01/24/2009 12:24 PM
It depends on what you are doing. If your products sell to various markets then use the most stringent. if you are going to a particular market then use the standard most applicable to that market.
Chas
Good Answers: 68
Re: Pull Force Test
01/24/2009 8:07 PM
Hello Peter,
Is it possible to tell me which of the 30 or so different gauge wire you use? It seems unlikely you will be testing more than about 6?
It would help if you can please?
Take care...................
Register to Reply 4 comments
babybear (1); Bill (1); capblanc (1); JCase (1)
