Previous in Forum: Meggar Test   Next in Forum: shart fall
Siemens Masterdrive
01/23/2009 11:38 AM
Hi folks,
I have a FOO26 fault appearing on my masterdrive, this fault means a ground fault on line 2. There is no external problem. What is the solution?
I know the problem is the drive because when I switch it to another working system the fault remains. The application is an elevator and the drive number is 1P6SE7023-8ED61Z.
Give Thanks 4 Life
Good Answers: 804
Re: Siemens Masterdrive
01/23/2009 1:19 PM
Have you tried calling Siemens?
Good Answers: 50
01/26/2009 3:45 AM
Try running with nothing connected on the output terminals, if it trips the same its definitely an internal fault.
Whether the internal fault (probably output transistor failure) is a faulty component or caused by installation / operation should be addressed by the original supplier - is it under guarantee or service contract. If you do go for repair, try to go somewhere where they've got good experience and diagnostic skills that may help prevent further problems.
If you end up paying for a replacement rather than repairing (repairing can end up with a 'faint friend') depends on the cost of it not being in action to you, but if you're paying for a complete unit you should consider changing manufacturer also to a more robust / reliable unit for your job / environment. Are you sure its not contaminated, for example?
Something new every day!
01/26/2009 7:57 AM
Thanks for your comments.
Give Thanks 4 Life
Register to Reply 3 comments
Appliedtech (1); JRaef (1); MalcolmK (1)
