Previous in Forum: Frame-VI Gas Turbine Mark-V Control   Next in Forum: Boeing 777 Tail Dock Design
Spherical Rubber Bearings
01/24/2009 4:05 AM
I am looking for a kind of spherical rubber bearing. please see the following attached image. but it is difficult to find a supplier who can produce the bearing. who can recommend some companies i can buy the bearing from?
the requirement of the bearing :
in the normal condition, the radical force can reach 200KN to 400kN. however in the very hard condition that hardly happens, the radical force can reach to 1200kN.
I expect someone could give me some pieces of good advice.
Pathfinder Tags: rubber bearing spherical
Good Answers: 103
Re: help me- spherical rubber bearing
01/24/2009 5:54 AM
Did you mean roller bearings or rubber bearings ?
What are the approximate diameters ? for a diameter of say 100mm the static load rating will be about 920KN for a double row spherical brg.
You can have spherical plain bearings too check the website of FAG or SKF
is it a rotating shaft ? The rubber material is supposed to result in high friction. We use rubber in certain cases only for vibration dampning (rubber film behind the sleeve of a sleeve bearing) but no relative movement takes place on the rubber surface.
Good Answers: 266
Re: Spherical Rubber Bearings
01/24/2009 7:29 AM
Looks like a Ball Joint Swivel Bearing. Google that.
01/24/2009 11:47 PM
Dear sir,
You can contact igus germany sperical polymer bearings and bushings,max uk.
sankar
Good Answers: 68
01/24/2009 11:53 PM
Hello elegantessay:
Do you want a 'bearing', or a spec as you describe for something to 'bare' on?
http://www.gmt.gb.com/?gclid=CLeqjbTxqJgCFQsyQgodtXKPnA
This company make some pretty hefty mountings. Worth a look? Does the rubber need a steel band on the inside if it is a bearing?
Or will a rubber of the right size and spec, with a steel rod through the center work?
Just a thought. This company do them all.
I am still looking. I entered Spherical Rubber Bearings 200KN to 1200KN.
Take care,....................
01/24/2009 11:58 PM
http://www.applerubber.com/
Your drawing looks familiar to me. It looks like a polymer spherical insert pressed into an elastomer isolator surrounded by a substantial, probably metal housing. Jaguar used almost the exact design you drew to hang the exhaust system in early ('68 to '73 anyway) XJ6's and is probably available from:
http://www.terrysjag.com/
or:
http://www.xks.com/
Nothing exceeds like excess.
01/25/2009 6:38 AM
You could try to find in a factory of rubber stuff,some "silent block" and combine that with a standard support bearing;you may try send to make a special "silent block" or try to find in companies whiches makes dampers-support for statics engines, i mean vibration isolators...Is not so clear to me what you are trying to do.-
01/26/2009 3:44 AM
Try contacting the German company IGUS (www.igus.de) they make all kinds of dry type bearings using synthetic materials
Regards,
Bruce
Register to Reply 7 comments
Anonymous Poster (1); babybear (1); Bruce Stanley (1); ferquiza (1); Jaguar (1); ozzb (1); sb (1)
