Previous in Forum: Capacitor banks...   Next in Forum: Lamp Testing
Waterproof USB Conectors
01/24/2009 6:59 AM
Is there such a thing as a waterproof femal usb connector that is good down to 6 feet with an outside dia. of .375 or less? With a panel mounting flange shallow enough to be mounted flush in 1/16 " material. The over all length can be more generious at .625".
Thanks for the time.
Good Answers: 38
Re: Waterproof USB Conectors
01/24/2009 10:50 AM
L-com has them, but you may want to try google.
Results 1 - 10 of about 709,000 for USB cable + waterproof. (0.22 seconds)
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
01/24/2009 10:59 AM
Thx,i googled "miniture waterproof usb connectors" and the landslide began
Good Answers: 62
01/25/2009 11:39 AM
To achieve waterproof as you have probably noticed, requires a pair (male and female) to make the connection.
Re: Waterproof USB Connectors
01/25/2009 2:01 PM
No sir I hadn't noticed and/or gotten that far into the connectors. But That makes perfect sense. The problem the company I work for (only as an electronics tech) is having stems from trying to make their product water proof to a depth of 6 feet using a regular USB female connector by sealing around the pc bd mounted housing and at the point where the connector passes through the component chassis. The whole thing is about the size of a i pod player.
There's no provision for a plug and/or cover for the USB connection as they would extend past the out side of the unit which is unacceptable. I seems to me they are attacking the symptoms rather then curing the problem of the USB port leaking when submerged.
Again I am researching this on my own hopefully to offer a solution to management. I appreciate yours and any one else's suggestions,comments and thoughts.
Thank you,
Register to Reply 4 comments
charsley99 (1); edignan (1); moperformance (2)
You might be interested in: USB Connectors, USB Products, Connector Plates
