Previous in Forum: how to make shop/detergant   Next in Forum: Tensile Stress Ratio in Pressure Vessel Design
9 comments
How to Cut Teeth on Long, Continuous Metal-Wire Strips
01/24/2009 6:59 AM
I am looking for some machine which can cut teeth on continuous long wire strip (say utpo 300 Mtrs or 500 Mtrs),
teeth as on saw blades, but my requirement is to cut much bigger teeth, teeth angles can vary, teeth size can vary and machine should be able to handle different width of of wire strip (say 5 mm to 20 mm)
Thanking you,
Dinesh Rewari
mail : rewari.dinesh@gmail.com
mob : +91 99960 22270
Also posted in: also posted in Mechanical Engineering
Good Answers: 103
Re: How to Cut Teeth on Long, Continuous Metal-Wire Strips
01/24/2009 8:03 AM
Look for a press with the profile/ variable profile - that will punch (shear) the teeth. The feeding can be automatic/ indexed.
Contact hydraulic press makers of your area.
The insulators, conductors, laminates etc are regularly punched (of course circular/ profile hole and not in the edge, but that doesn't matter) by this method.
01/24/2009 11:41 PM
When I saw the title, I thought of your baby:
Good Answers: 74
01/25/2009 4:53 AM
Like your sub! Ky.
The Twain Has Met
Good Answers: 183
01/25/2009 8:07 AM
The technology depends on 3 parameters:
- band thickness
- surface quality of cut
- dimensional precision of cut profile.
If requirements are NOT excessive the most promising technology is laser cutting.
The band has a piloted constant advance velocity and the laser ray has the transversal movement. Both have to be synchronised which is today quite easy to do. The advantage is the programmability low cost of the system only software has to be adjusted to new profile.
The recommended presses require a heavy tool justified as cost only if the precision is high and series are important.
Good Answers: 243
01/25/2009 5:53 PM
As long as teeth stay in same plane as strip this will work, If 'teeth' are offset outboard from strip's center line, this isn't sufficient. Also, metallurgical characteristics of the strip may be important on means other than laser cutting.
milo
Good Answers: 183
01/25/2009 6:00 PM
Cutting can be done before heat treatment if it is required so that the strip structure will be according to needs at end.
As far as I understood it is a strip to be cut, usually in such a case teeth are in the plane of strip. I do not imagine a strip with teeth cut in the strip mass; if so it will not be a cutting but more a 3D deformation as forging.
But of course as always I may be wrong.
Good Answers: 243
01/25/2009 6:22 PM
I was thinking about the 'set' of the teeth being out side the "width" of the strip, which is why kerf loss is always thicker than the main band of a blade, the teeth are offset out board and so thicker. I liked your answer, just wanted to add some add'l insight.
see photo
http://photos.custompc.co.uk/blogs/syrillian/files/2008/05/4-accounting-for-the-blade-thickness.jpg
milo
Good Answers: 183
01/26/2009 1:03 PM
I agree with you. The side off-set can be done after cutting and before heat treatment on the run of the strip. With laser cutting it is easier to modify the profile and if the strip is not too thick productivity is tremendous.
Off-set can be done with 2 synchronised profile wheels but then at every pitch change the wheels have also to be changed.
01/26/2009 5:23 AM
with a continuous teeth cutting machine
Register to Reply 9 comments
Gwen.Stouthuysen (1); ky (1); Milo (2); nick name (3); sb (1); StandardsGuy (1)
