Previous in Forum: Density-Related Gas Separation   Next in Forum: Spherical valve
Resleeving Backup Rolls for Rolling Mills
01/24/2009 12:14 PM
ALL BIG ROLLING MILLS USE BACKUP ROLLS WITH THE WORK ROLLS. THESE ROLLS ARE OF UPTO 1500MM DIA X 8000MM LONG WITH BARREL UPTO 2000MM.
WE UNDERSTAND THAT ROLLING MILLS IN EUROPE AND AMERICA ARE RESLEEVING THE OLD & WORN OUT ROLLS BY GRINDING, AND THEN SHRUNK FITTING NEW SLEEVES ON THE BARREL.WANT HELP IN THIS PROCESS.
JAY SUREKA
jaysureka@hotmail.com
Re: Resleeving Backup Rolls for Rolling Mills
01/25/2009 9:53 PM
Also, Timken is into roll repair:
http://www.timken.com/en-us/products/remanufacture/industrial/Pages/Roll.aspx
Timken did weld build-up on backup and work rolls for an aluminum mill here.
I can't imagine a sleeve staying in place, and not squirming around!
Good Answers: 243
01/26/2009 7:48 AM
what you and I believe a sleeve to be may be different than the op.
maybe not.
Thanks for the tip on timken.
milo
Engineering Fields - Energy Engineering - Electronic Condensate Controller
Location: Marysville,Wa 98270 also on Lopez Island in the San Juan Islands, Wa
Re: Re-sleeving Backup Rolls for Rolling Mills
02/05/2009 12:59 AM
I have worked on Sleeving Rolls. Teflon Sleeves,Teflon Glue, Heat Shrinking the Sleeve by Blowing Hot air from 3 Electric Heat Guns, While roll is slowly turning in a Roll Grinder as the Heat gun assembly move from one end roll grinder to other. Roll is ground first, before new sleeve is installed, Roll is kept turning slowly over night to cure glue and keep Roll Round, roll will sag in middle if stopped turning and could not be ground round with a bend in the middle of the roll . Sleeve is then ground to specs using a grinding stone and running a special grinding coolant. Metso Paper company has recovered many types of Rolls with special rubber compounds that were compatible with all of our sleeved or unsleeved Roll needs, I have also used Steam to Heat Shrink Plastic Type Roll Cover on large Suction Rolls. DonnieH
Conserving thru Efficiency Donald G Holscher
Register to Reply 3 comments
Don in Richmond (1); DonnieH (1); Milo (1)
You might be interested in: Process Rolls and Rollers, Rolling Mills
