I want to build a small radiant heat panel for some reptile cages. I am currently using commercially available heat panels, but would like to build my own.
I took apart one of the units that I have now,to see how it is made and it is really quite simple.
They have adhered an insulated Ni Chrome wire to an aluminum plate of about .032" thick. The wire is then covered with a foil reflective cover. Over that is a piece of glass insulating board. The whole thing is contained in a metal framework. The wire is 34 gauge and is 22.5 feet long laid out in a zig zag pattern. The maximum temperature is around 150 degrees and it runs on std house current. I control output with a digital proportional thermostat.
My problem is that I cannot find this wire in small quantities. I have found some other sizes that are very close and I need to know how this would be compensated for in order to achieve the same temperature.
