Previous in Forum: robots   Next in Forum: Painting Galvanized Flashing Indoors
Fan Air Loss
01/27/2009 10:44 AM
We have to move a cooling fan on an engine, we have to fit the engine in a confined space and the fan diameter is too large.
We have a 23" Fan and we need to cut 1" off for a total diameter of 21"
turning at 2200 rpm, how mush air loss can we expect? approximate?
Re: Fan Air Loss
01/27/2009 11:26 AM
Other things equal, the amount of air you lose will go as the square of the change in fan diameter. Now if the fan speeds up because there is a smaller load on the fan motor, then that will partially compensate for the smaller diameter. If that happens or not depends on the type of motor used. You could also change fan blade pitch to compensate for the reduced diameter to maintain constant airflow.
Good Answers: 62
Re: Fan Air Loss
01/27/2009 4:27 PM
Or remount smaller fan on smaller pulley if belt driven.
Or go to electric fan and pick your own.
Good Answers: 54
Re: Fan Air Loss
01/28/2009 1:43 AM
As emcc says use the ratio of swept area.
ie ∏(23/2)² : ∏(21/2)² Canceling the common things on both sides gives you 23² : 21²
So the flow will be about 83% of the original amount
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Re: Fan Air Loss
01/28/2009 10:57 AM
As long as you are not in an area of extreme temperatures, you should not notice any differences, they are designed to work in extremes of temperature, so at lesser temps, its sometimes "over done!"...
Register to Reply 4 comments
Andy Germany (1); edignan (1); emc_c (1); ffej (1)
