Previous in Forum: How to Become a Manufacturer and Distributor of RTD Elements   Next in Forum: Building a Wood Burning Stove
ASME Certification in GD&T
01/28/2009 2:07 AM
Hi,
iam working as a design engineer.Since i dont have much experience ,i would like to pursue ASME Certification in Geometric Dimensioning and Tolerancing (GD&T)
so i would like to know whether this certification really helpful in getting jobs.. & improving skills...& will it really give any priority in getting jobs?..
please clarify me...
Thanks...
User-tagged by 1 user
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: ASME Certification in GD&T
01/28/2009 8:03 AM
Take a look at what ASME itself has to say about this subject. Specifically, refer to the "Why get ASME GDTP Certified?" section on this page.
01/28/2009 12:44 PM
You should know that from a part producer's view it lets them use good parts that might otherwise be rejected. This is more important in plastic part design than metal, because plastic moves around more as it changes temperature.
While it's important to design, it's real payoff comes in inspection and assembly.
Get certified!
01/29/2009 9:00 AM
Hey good idea.... for me too.
Anyone here taken it, do you have any study guides to recommend besides the "book" itself?
Live Slow - Sail Fast
01/29/2009 10:49 AM
Yes.
Did the prep class and the 4 hour exam. It wasn't pleasant! But very, VERY usefully.
Now "they", (Design, MFG, QA) think I'm some kind of the GD&T guru. So I'd say it does give some advantage. (Honestly GD&T is so...miss understood that all I really know is where to look in ASME 14.5M Standard for explanation.)
Good luck!
Sucess is going from failure to failure without loss of enthusiasm... Winston Churchill
01/29/2009 6:56 PM
Thank you so much for your reply....
Is ASME GD&T material easy to understand?..because its a self study material...& if i pay the fee mentioned as $695, can i get ASME GD&T 14.5M standard along with materials?..
please help me...!!
Thanks...
Location: Globaly - very close to the southern most point of Canada
Good Answers: 12
01/29/2009 9:44 AM
If you have the opportunity to become certified and it is the dierction you want to take then do it for sure.
The certification can help you get a job and the knowledge will help you keep it.
-why bother doing it wrong when it will be anyway.......
Good Answers: 68
01/30/2009 9:45 PM
Hello bharath0205:
I think you have the right idea. To work in that area though you must be observant and measure over and over again. As was mentions plastics perhaps more than anything is demanding to try and make a product which looks great and it actually stands up without leaning one way or another! You thing you have it sorted and a new mix or type of plastic is used and it is back to the drawing board.
Most small house-hold radios, phones etc are plastic and it can be very difficult to make a product which stands out. It will be part of your job to choose the correct or most suitable 'poly' mix for an item.. And the finish on some of the plastic computer cases is so highly glossy it is hard to imagine it was some skillfully bloke like you will be if you work hard, who actually designed these cases!
Take care and good luck OK?
Register to Reply 7 comments
babybear (1); bharath0205 (1); CaptnPea (1); gdevine (1); lyn (1); Q (1); Steve Melito (1)
