Previous in Forum: Mechanical Efficiency of Tandem Truck Transmission   Next in Forum: Machining time
37 comments
1994 Mitsubishi - 4M40 Engine Breather Blows Oil
01/30/2009 1:43 AM
hi all i have noticed that most of the 4M40 engines of 1994 have this problem of passing oil from the breather pipe that connects from the Top engine cover to the air filter
these engines are found on Pajero`s and Delica space gear this seems Mitsubishi is aware of this problem and i was told by a mechanic in Mitsubishi that when they claimed of this problem the were sent new half engine blocks but never reviled what caused or was the problem
Could it be Pistons Rings sleeves? The engine already has new rings.
On later model this problem does nor exist
note that compression readings are OK.
if not controlled one may drive and run out of Oil !
Re: Mitsubishi 4M40 engine brether blow oil despite new rings
01/30/2009 3:12 AM
Did you do the re ring are did someone else do it. This is a symptom of blow by and these engines are very specific to assembly guidelines. Here is a link to a free service manual to the 4M40 engine.
http://www.onlinefreeebooks.net/automotive-machinery-power-equipment-ebooks/mitsubishi/mitsubishi-engine-4m40-workshop-manual-pdf.html
I would study the area dealing with the piston and rings and see if everything was assembled properly. and pay special attention to the letter identification of the piston to the cylinder as it is stamped on the block. A lot of people are not aware of this detail of the 4M40 Engine. Good Luck and hope it helps.
Jim
01/30/2009 8:05 AM
Yes went through the manual my self set the ring gap as specified sleeves are within tolorance no rig at all but still after running some 300kms oil is sucked via this breather pipe and ends up being burnt through the inlet strange you don't see any sign of oil or smoke at the tail of the exhaust pipe oil simply runs low
am thinking of using an external breather any idea ?
01/30/2009 8:44 AM
Have you checked the valve seals? That can cause blow-back
01/30/2009 8:51 AM
Valve seals and guides new! valve seats sealing well New turbo west gate open @ 1 bar
runs ok only this blow problem
Good Answers: 18
01/31/2009 2:13 AM
Vercellese After the new rings were installed did you follow the break in procedures? This information is normally in the engine manual & typically calls for the use of a specific engine oil (normally a non-detergent) for a specific number of miles. If the rings don't break in during this period they will never break in. Never use a synthetic oil until after things are completely worn in. After the break in period a synthetic would be your best choice for longevity of the engine. J.Conway
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
01/31/2009 2:43 AM
I use Castrol Turbo Fleet SAE 15w-40 from South Africa. (vehicle operates in Uganda)
Note this Oil is commonly used in East Africa and never had any problems reported.
I have run in the engine now for 10000 kms But still this problem exists
I tried to contact other friends in Nairobi (Kenya) and they confirmed that they also faced the same problem and when they contacted Mitsubishi dealers they were replaced with New half engine Blocks complete with Pistons installed But No body tried to find out what the problem is.
may be Mitsubishi are hiding something?
Good Answers: 18
01/31/2009 3:10 AM
Vercellese This appears to be the cause of your problem, this oil probly hasn't allowed the rings to seat, this is a critical step in breaking them in. I crew chief for two race teams and we had one engine this past season that the rings failed to seat. This was a brand new GM crate engine, we performed the recommended break in procedures and after four races we pulled the engine and found that on two cylinders the rings never seat. This required honing the cylinders and installing new rings. We use a straight 30 weight non-detergent for around 50 miles for our break in, then change to synthetic racing oil. J.Conway
02/01/2009 2:22 PM
On the ball!
02/06/2009 7:19 AM
You are right! I have been using synthetic for almost 20 years and the wear (and of course the "wear-in") is dramatically reduced.
With new VW TDI motors (I have had 5 over the last 12 years), the first 10,000 kms uses quite an lot of oil. Right up to 100,000 kms or so, the oil usage gradually tapers off.
I only consider a TDI engine to be fully "Run-in" when it has more than 80,000 kms on the clock......the oil usage is then usually down to a liter in 15,000 kms or less.....my present engine is running at 93,000 with about 0.5 liter per 15,000 kms....
Interestingly enough, on my earlier VW TDIs, the handbook required at least 5,000 kms to be driven before towing a heavy trailer, "OTHERWISE OIL USAGE MIGHT REMAIN HIGH FOR THE LIFE OF THE ENGINE"
Its not in any of the recent manuals, but I still follow this religiously and have had no problems........
02/01/2009 2:20 PM
Mate,
Worn valve stem seals will cause smoking at start-up but will have very litlle influance on oil usage..it will just do the exhaust system and rings some good!
You seem to have blow-by [Gas leakage past rings.... or rings skating on to much oil]
Good Answers: 18
Re: 1994 Mitsubishi - 4M40 Engine Breather Blows Oil
01/31/2009 2:36 AM
Vercellese. You stated the sleeves were within spec, was this after honing to true up and create a good lap pattern to help the rings to seat? J.Conway
01/31/2009 2:51 AM
Yes i used 2S Plateau honing just as per Technical highlights manual
Rings to groove clearance
1st = 0.03
2nd = 0.07
3rd Oil ring = 0.03 mm
01/31/2009 6:02 AM
1st = 0.03
2nd = 0.07
If the above numbers are actually the end gap measurements then they are way to tight in the cylinders as the end gaps should be 1st and 2nd rings .3-.45 limit .8 mm and the oil ring should have.3-.5 limit .8 non turbo .25-.45 limit .8mm
2. Have you pulled the crankcase breather tube and seen how much blow by you are getting blowing out to atmosphere. If it has a large amount of blow by you have one of two problems.
A. Compression bypassing the piston.
B. Stopped up crankcase vent causing oil to be blown past the seals or gaskets which should be able to be seen by inspecting under the engine to see if there is any place that you can see an oil leak.
Jim
01/31/2009 7:30 AM
There is no sign of any leakage all engine is well dry.
The breather tube show a normal blow out
am suspecting either too much oil is going to the cylinder head or the top cover vent is a faulty design.
question is why would Mitsubishi send in New half engine blocks to replace the exiting ones? curiosity!!
am looking for an external breather vent to try out
01/31/2009 8:46 AM
SNATCH OFF THE VALVE COVER WHEN THE ENGINE IS SMOKING. USE PIG BLANKETS/SUCKUPS TO PREVENT A FIRE. TOP END OILING PROBLEMS ABOUND, EITHER ITS OVERPUMPING OR NOT DRAINING. SOUNDS LIKE YOU'VE GOT THE RING PROBLEM SOLVED, BUT I'VE PUT IN LOPSIDED RINGS WHICH NEVER SEALED. ONLY BY INSPECTING THE WEAR POINTS ON THE RING FACES DID I FIND MY FAVORITE BRAND OF RINGS (HASTINGS) HAD A BAD BATCH. MASS PRODUCTION HAPPENS. I STILL USE THEM IN THE RACE MOTOR.
01/31/2009 9:43 AM
Do the compression test on each cylinder again with throttle wide open, note each reading.
Pop a few spoonfuls of oil in a cylinder, make the test again. Then the next cylinder also with oil and pressure check....and so on for each cylinder.
If there is a 5% or more increase in pressure, then the pistons/rings are not sealing, if there is no difference, the valves are at fault!!
It may be only one cylinder at fault by the way.......
02/01/2009 2:43 PM
Sorry Andy,
Compression tests are of little use. Rather do a propper cylinder leakage test[Engine at working temp.; piston at tdc and compressed air through plug hole introduced throug tester.] This test can determine exactly if you have any one of the valves , or the rings and/ or gasket or cracks leaking. It is normal to have up to even 30% leakage past the rings and that would still not amount to eccessive blow by.
Valve leaking would not cause blow by.
I have seen Mercedes engines which had rings as good as baling wire having blow by from day one. I actualliy knotted these ring with my hands!!! [Mercedes are still......investigating....with NO re fund!]
02/01/2009 2:55 PM
....agreed if the person testing has the equipment. I understood that he did not have much, so I made the test as simple as possible......
He can make a choice of what he is able to do now.......
01/31/2009 12:55 PM
Your rings are not seating or the piston and sleeve are already oval. The other reason could be scratches on the piston or sleeve.
As your piston moves up and down in the sleeve, irregular oil changes, wrong oil, or the wrong grade of oil could accelerate the wear on your pistons.
When you replaced your rings, did you hone the sleeve?
Many backyard mechanics do not do that and then the new rings fail to "bed" in the honed cylinder.
Also check that you have the correct rings fitted as you get stailess steel or cast rings.
Thye gap in your ring ends are critical.
A broken ring could also cause the problem.
Please also check for a scraper ring,(The second one) which was fitted the wrong way around.
Ronny Moore
01/31/2009 9:47 PM
Hi , im no ace mechanic but i have been around engines for quite a while , my thoughts concerning your problem, are as follows.
I think your engine is probably fine as far as oil control rings and valves etc.
I suspect a simple design flaw in the breather pipe to air intake system .
That being said , im not sure why Mitsubishi would send out half engine blocks to correct this but " who knows " ?
Question ., is this problem with the P.C.V. system or a simple breather pipe ?
If the P.V.C. system is involved , make sure it is clear , make sure the P.V.C. valve is not installed backwards and generally check for proper operation.
If we are talking about a simple breather pipe from the valve cover to the intake then i would look for the absence of a deflector or baffle to prevent oil from simply being sucked into the air intake system , " the design flaw ".
Remove the valve cover , turn it over and look for a baffle at the breather pipe fitting, if there is none then there is nothing to stop the engine from simply sucking the oil that is flying off the valve train into the intake system .
Fix this by tacking a metal hood over the hole to prevent oil getting sucked in but leave an opening parallel to the valve cover to allow the engine to breath .
Hope this helps .
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
02/02/2009 1:10 AM
Gentleman i did change the Top cover on Saturday, replaced it with a new one and seems the problem is kind of solved i have run some 300 kms @ 140 kph and d`int notice any oil loss oh i did also change another type of air filter so it could have either been the Top cover vent problem or the previous type of air filter used.
Cross fingers!! still testing and will keep you all posted!
never the less i still wounder why did Mitsubishi replace for New Half blocks???
Good Answers: 123
02/04/2009 9:20 AM
Mitsubishi replaced the "half engines" because they had to. Either Mitsubishi does not trust it's own trained mechanics to replace pistons and rings, OR, the factory knows that there is something wrong with their blocks.
It could be that the cylinder walls do not stay round after use. It could be a metal composition problem. But it seems that the engine block is the problem.
The wet to dry compression test will yield information. The cylinder leak down test will yield information. but the real answer is to use the time tested methods. dismantle the engine again and mike the bores all the way around, and all the way up and down.
If you want the answers, that is the way to find out. If your bores are out of round, you could re-sleeve it with replacement sleeves. The replacement sleeves are made of a better material than original blocks are usually.
Sounds like a lot of work now for just a little blow by.
Bob
12/15/2009 11:03 AM
My 4m40 breather blows oil also, before and after a complete rebuild, when you change the valve cover was the problem solved.
12/15/2009 11:10 AM
Thank you for letting me "rebuild" your engine. This was going to be a bad Christmas this year. Thank goodness you came into my life. The can of engine paint allowed a complete rebuild at a very reasonable cost to me. Again thank you for letting me spend lots of your money this Christmas.
12/11/2010 11:45 AM
I also had the same problem with a 4m40 engine, thus i took off the rocker cover and flushed the breather with caustic soda and hot water, a lot of messy sludge came out of there . problem fixed no more oil loss.
02/01/2009 2:11 PM
If the engine cylinders were within spec's when you had new rings fitted and the pistonring clearence in their grooves where ok then ......the oil pressure might be to high causing the ring to plane on the excess oil beiing squirted on the cylinder walls!!!
Check oil pressure and bring down oil pressure to the lowests specs of manufacturer at the pressure relief valve by the oil pump or on the main oil gallery.[Lowering the relief valve sping tension]
Before the above: Make sure the glaze on the cylinder walls were propperly removed by honing the cylinders and that top-class rings were fitted!!!
Jurie za
02/01/2009 2:53 PM
Hate to say this, but that is a wonderful Fairy Tale, I laughed my socks off.LOL
02/01/2009 7:42 PM
Andy,
I love German cars,got a Mercedes myself. On the 230/4 they did not dril oil holes in the oil rail to lub the exhaust lobes of the camshaft and many had to have camshafts replaced! Any manufacturer sometimes slip up!
You can keep your socks on, I have proof about the dud rings that was fitted to a batch of Merc 200's. No reason to talk nonsens.
02/02/2009 3:14 AM
Mercedes are far From being my favorite car, I see from relatively close up how they bodge fixes and overcharge customers for spares......as do BMW.
Some of their mistakes are passed onto the customer to pay for.....about 10 years ago, you had to buy a complete rear axle if the sensor broke for the ABS!!! Instead of like $10, they charged $6000......now that is bad planning........don't buy any T models of the late 80's and 90's with ABS by the way.....the problem has not been fixed, at least not here in Germany.....
Both Mercs and BMW have somehow conned the world into believing that they are good. Bu to my mind neither are cars for people (retired) with limited means at their disposal....like myself.
My favorite German make is Audi, we have one as a second car and our main transport is a Diesel Mitsubishi Grandis, my favorite Marque of Japanese cars for many years now......my presnt Mitsubishi has a VW 2.0 TDI Diesel engine as the Mitsubishi Diesels, although reliable are not good enough with consumption for the Euro market.
04/23/2010 1:45 AM
Clean the aircleaner vent valve in the tappet cover will cure it.
Or replace the tappet cover.
04/23/2010 2:47 AM
finaly i managed to hve a chance to see the new type of the 4M40 engine and guess what!
the Piston and Rings were modified,it was enough for Mitsubishi to release a TSB concerning this problem, but for some reason they decided to hide this problem
and just supplied new half blocks with pistons ready inserted, to their dealers and keep muum. same thing regarding
Toyota Rav4 A/T problems that are caused by a faulty ECU, but never mentioned, Shame!!!!
04/23/2010 7:35 AM
Wrong blog, comment erased.
07/23/2025 2:33 AM
My 96 challenger had this problem, about 1 litre every 100ks was disapearing fast, no oil leaks and no blue smoke turbo and intercooler were full of oil. I developed a fix for this and now my one is perfectly dry and uses no oil.
07/23/2025 11:49 AM
So, how'd you fix it?
HUSH
07/23/2025 3:47 PM
Yeah, what Hush said.
What was the problem (how did the oil get in the turbo) and how did you fix it?
07/24/2025 3:29 AM
The short answer is I removed the origonal breather. (short pipe from oil seperator to the inlet hose just after air cleaner)
Then I fitted a longer hose from the oil seperator. This hose is more than 1 metre long and has a slight uphill rise as it travels around to the other side of engine, then runs through a pipe that discharges down near the bottom of the engine.
The long answer
I checked the oil after a trip to the city and there was nothing showing on the dipstick,so no oil leaks and no blue smoke,and it had an oil change and filter, it must be going out the breather. The origonal breather runs from an oil seperator in the tappett cover direct to a connection on the inlet just after the air filter and goes through the turbo and intercooler all which where full off oil. I installed a catch can here and tried different lengths of hose and different positions getting a slight improvement each day. The test was the run to work up a mountain on a gravel road about 50k's each day. I seen a slight improvement with each mod. It was losing a cup of oil each trip at the start. Next I fabricated a baffle that is in the rocker area and stops the splash from the rockers getting delivered into the oil seperator and then the breather and getting sucked through the motor, that was another improvement and I was only losing about a teaspoon of oil each trip at this stage. Next i dissconnected the breather from the inlet to the turbo and intercooler so it was not getting the slight venturi affect from there and then through the catch can was only a few drops of oil getting lost. I had the outlet from the catch can discharging into a small aluminium container and there was no loss of oil here now.The next mod was I moved the catch can to the far opposite side of the engine bay and increased the length of the hose, the breather hose in now more than 1 metre long and runs uphill from the tappet cover to the catch can. Now there is no oil lost from the engine at all, the catch can simply breathing through an open pipe down under the vehicle. Every thing is good now and if I continue with the mods I might remove the catch can from the system.(catch can now removed and breather discharges through pipe that runs down near the bottom of engine)
Debrief
I think that my vehical had an early version of the oil seperator as it looks different from any other ones I have seen. I removed the rivets and internals of oil seperator for cleaning,then refitted with screws tapped into rocker cover where the rivets were. I thought that the breather was acting like a venturi and sucking the oil out of the engine. The theory is that any oil pushed out the breather now has a chance to run back to the engine.
Further info
I purchased the vehicle from a dealer in Invercargill,they purchased it from its former owner in queenstown where it was in a repair workshop and they must have been installing a new head. There is evidence of there being two heads purchased from Kiwi Heads, as there was an extra head gasket set, left over with brand new camshaft were with the vehical. There must have been an issue with the first head and a second head was installed. Now the next problem is that they could not get the vehicle to start and run and it was sold as is, and not running, so the workshop in Queenstown and the guys in Invercargill had all tried to get it running, and failed. The front timing cover and the fuel injector pump where never removed from the vehicle during there procedure so it was thought that nothing can move down there all they need to do was time the camshaft when refitting the timing chain. They were wrong in thinking that. It took me a couple of weeks to nut out the fix for that.
07/24/2025 4:05 AM
Thank for jumping in with that. Creative solution!
Register to Reply 37 comments
Andy Germany (6); Anonymous Poster (5); bob c (1); Doorman (2); healybj8 (1); HUSH (1); Jerrell Conway (3); Jspeop (2); jurie sa (5); machine head (1); petermcg (2); ray cockrell (1); Vercellese (7)
