Hello
First thanks to every person for the reply.
The detail is as
I have 3 phase ac supply
Voltage = volts line to line 420 Ac
Current drawn by inverter is 130 Ampares (meassured with clamp on tester)
COS phy is .92
Load on invrter is 250 kw ac motor delta connected
current drawn by motor 370 ampares ac(meassured with clamp meter)
Voltage at motor 425 volt ac line to line
Cos Phy of inverter .95
Our electrical engineer say that this inverter is based on new techniques.
This is a energy saving device according his statement that we are saving 60%
electrical energy .Inside the inverter Buck boost converter and inverter are used.
The supplier table is going to indicate that input current to inverter and otput
current is equal. 3 phase rectfiers are 6 four quadrant mos fet modren switches.
output of dc is 560 volts dc= 1.35x L to L(rms)value of supply to inverter.
Please studdy this case carefully because our electrical engineer raised demand
to purchase more inerverter so to save more energy. Conventional Kwhr meter
are also reading the same value as input current to nverter.
Please answer
Thanks
Remain in contact
Abdul
