Previous in Forum: Crack Detection of Elevator / Escalator Panel   Next in Forum: Desiccant dryer
Excessive Vibration at Exhaust Fan
01/30/2009 12:07 PM
My query as below:
Fan Installation & Control
1. Two centrifugal exhaust fans have same fan static pressure (6"WG) & capacity (20,000 cfm) are placed in parallel.
2. Each exhaust fan has own individual outlet duct which is connected to individual chimney.
3. Each exhaust fan inlet shares same duct plenum which is further connected to main duct & branch ducts at production floor.
4. The duct plenum & main duct are sized for 20,000 cfm only.
5. Each exhaust fan motor speed is variable speed & controlled by Variable Frequency Drive (VFD).
6. Pressure transmitter installed at main duct is used to change the fan motor speed when there is a change of exhaust demand at branch ducts.
Scenario 1
1. Exhaust demand is less than fan capacity (15% of fan capacity).
2. When one exhaust fan is running, acceptable vibration at exhaust fan, chimney & duct.
Scenario 2
2. When two exhaust fans are running, one of the fan brake horse power is half of the another one.
3. Acceptable vibration at exhaust fan, chimney & duct.
Scenario 3
2. When two exhaust fans are running & have same brake horse power.
3. Excessive vibration at exhaust fan, chimney & duct.
My question is could someone advise me what has happened to the system ?
Good Answers: 103
Re: Excessive vibration at the exhaust fan when both are running
01/30/2009 12:39 PM
The system is resonating when the two fans are running at the RPM.
Try running one of the fans at slightly less speed and see.
Preferably put vibration isolators below the fan mounting plate.
We have seen this type of resonance in several thermal power stations (The Pulveriser vibrations were transmitted to Boiler Feed Pumps- in a particular type of lay-out)
The vibration damper isolators had to be installed.
Re: Excessive Vibration at Exhaust Fan
01/31/2009 11:47 AM
Are the fans direct drive or belt?
It's better to burn out than rust out
02/01/2009 10:11 AM
The fans are belt driven.
02/01/2009 4:57 PM
I've had this problem before in belt drives because of the ratio. If you are driving with a ratio of 2:1 for instance it works fine but if due to your pulley size your ratio is close to, but not 2:1 like 1.95:1 there is a harmonic vibration. If you change the ratio to 1.8:1, the vibration stops. I believe this is true of all whole numbers.
Register to Reply 4 comments
bwchoo (1); ripsaw (2); sb (1)
