Previous in Forum: Bigger is not better   Next in Forum: Smooth finish inside Dia 1.1mm
Pump pressure
01/30/2009 8:58 PM
I have a cinder spreader which is pto driven from a tractor and I'm trying to hook Hyd. to run it off my skidsteer. My skid steer puts out 22 gal per min. and 2800 lbs.pressure, I have a Char-Lynn motor which I would like to use but not sure if it will work, the specs are on the motor RPM @12 GPM - 914 Max PSI is 1800.my concern is if the motor will take the pressure, I'm also planning on using a adjustable flow valve which I have. If the pressure is a real concern should I add a pressure relief valve.I just don't want to blow the motor apart. Thanks.
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
Re: Pump pressure
02/01/2009 2:02 AM
Hi Digger104
What RPM do you actually require for the cinder spreader? What is the gear ratio when driven by PTO?
The skid-steer presumably requires most of the available oil output just to operate 'as is' so, you will need to re-use the oil. This will be a matter of compromise as the skid-steer performance will be reduced to accommodate the required oil for the cinder spreader.
You will need, probably, a 'pressure compensated flow control' to give you what you will require for the cinder spreader but, this will depend on the type of pump on the skid-steer. If this pump is fixed displacement, you would use the PCFC to 'bleed oil' off the existing system. If the pump is variable displacement then a simple throttle may suffice however, this only takes care of the RPM of the cinder spreader. You would need a three port 'pressure reducing valve' (with perhaps a fourth port to tank) to give you a sub-circuit operating at a lower pressure than the main system.
If the current skid-steer hydraulic system is hydrostatic (most likely) operating in closed loop, leave that system alone. There will also be a charge pump (fixed displacement and usually quite small) operating off the back of the hydrostatic pump. Leave this alone as well. Look for a small to medium sized independent pump working in open circuit that would operate external cylinders. Look to divide the flow from this pump as indicated above with a PRV and/or PCFC. Also give a thought to cooling. If there is pressure drop (across a motor), there is heat generated!
Also the motor that you have may not have sufficient bearing capacity in the nose but I'm unsure how you intend to configure the cinder spreader!
Any extra information you can provide will give you a more definitive answer.
Good luck with it!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
Re: Pump pressure
02/01/2009 2:57 AM
Do you have a fixed pump or variable displacement pump? What is the year and manufacture of the machine with the pump?
Re: Pump pressure
02/01/2009 7:50 AM
HI and thanks for the response. I have two skid steers which I will use. the one is a 2004 277B Cat rubber track and the other is a 2006 Bobcat S220, I'm not sure what pump they have, but I was just going to use the aux hydraulics used to run other equipment. I do think I have this figured out, I'm planing on using a adjustable flow control valve with a built in relief value. Thanks.
Re: Pump pressure
02/01/2009 12:09 PM
You have it under control that way. Also you can mount the flow control valve on the spreader then it will work on ether machine with out change the machine settings.
Re: Pump pressure
02/01/2009 6:02 PM
Hi Digger104
If you intend to use the lower pressure rated motor, DONT use your valve with a pressure relief built in to achieve the lower pressure. It would either lower the pressure so that existing cylinders wouldn't work (or lift enough) or cook the oil.
You will need a pressure REDUCING valve which operates differently to a pressure relief valve.
I would recommend that you 'Tee' into the existing system with the PRV to give you a system leg that you can run the motor from.
You will also need a control valve that is open centre when closed to allow the motor to run down progressively when switched off otherwise you may suck the seals out of the motor!
Watch that you don't throttle the aux pump. It will be a fixed displacement and MUST displace the oil/rev. You would need to 'bleed off' oil to the motor to progressively slow it down.
Good luck!
Re: Pump pressure
02/01/2009 10:16 AM
If you have a Bobcat skid steer, aux. hydraulics is just that. It is extra hydraulics, a seperate pump than your mobile hydraulics. you will need a 4 way valve with open center and pressurre relief. A flow control will also give you speed control, PTO is about 500 rpm
Re: Pump pressure
02/01/2009 11:56 AM
yes of corse you can put in a .. bipasse valve on the controll valve you put it on the out going pipe . going to the motor if your motor cant handel it get a roller statore. its called made in usa. they are fast and plenty power you have got to watch things dont heat up? may have to have a cooler on.
Register to Reply 7 comments
andrew i wiseman (1); Anonymous Poster (1); Beej50 (2); digger104 (1); tundra bear (2)
