Previous in Forum: Reciprocating Compressors   Next in Forum: Fischer_Throupch for Synthetic Oil
12 comments
Do CFL/LED really save energy?
01/31/2009 6:41 AM
Best wishes to all!
Just food for thought: I am currently living in a rented flat; it's now -8C outdoors.
Am also stuck w/ electric resistance heating at this location.
In this situation, doesn't the "waste" from an incandescent just become space heat?
All that, & NO Hg!
If you always do what you've always done, You'll always get what you've always had!
Good Answers: 103
Re: Do CFL/LED really save energy?
01/31/2009 7:23 AM
Correct.
However the lamp is going to heat the total area uniformly and at a very low rate whereas Elect heater - radiators can go more for a zonal heating - at a high rate.
Anyway the incandescant lamp heat will not be enough for you, since the amount of heat it produces is likely to be lost at -8oC through normal insulation losses.
01/31/2009 7:40 AM
Many thanks for your reply! The -8C here is much warmer than last week's -15!
The zoning isn't precise enough to make it feel 'balmy'.
Just wanted confirmation on my thoughts: "Change to efficient lighting, & you'll save the Earth!" is not fully accurate. Much more study is req'd; individual solutions for individual needs.
Good Answers: 146
01/31/2009 2:18 PM
I work with silver, which tarnishes readily if exposed to cold and damp. Wierd things happen to the temper as well, if the temperature fluctuates to the colder extremes. I find that incandescent task lighting is a best choice for me, as it adds that little bit of heat as well, right to the place where I need it.
So although I 've been using compact fluorescents for general lighting for 15 years, I am with you on this: that there are contexts where the dissipation of some heat is a good thing in a light! (and it's also true, the incandescent light is better for task and easier on my eyes....)
From a strictly practical heat cost pov, I guess compare voltage vs amperage of a light bulb vs your heaters, where lower voltage = higher amperage, and therefore power cost...
incus opella
Good Answers: 103
02/01/2009 12:01 AM
The home aquarium, I prefer incandescant (assuming that the fishes will prefer them of course) it keeps them nice warm and happy , though never seen them nor .
02/01/2009 3:55 AM
If you use incandescents for winter light with the beneficial side effect of extra heating, what are you going to do in summer? Or perhaps your nights are still cool enough to need heat?
I agree, however, that blanket "solutions" foisted on people by well meaning individuals/organizations frequently have unintended side effects.
I am thinking here of the push to legislate to outlaw incandescent bulbs and force the use of "energy efficient" lighting.
Perhaps W.S Gilbert got it right in "Iolanthe"
"And while the house of peers withholds, it's legislative hand,
And noble statesmen do not itch, to interfere in matters which they do not understand,
As bright shall shine Great Britains rays, as in King Gearge's glorious days..."
Enough raving
02/01/2009 7:36 AM
Sceptic: You caught my meaning. There are often several solutions to any problem. Some critical thought to weed through to the best gives the most satisfaction.
BTW: do not need the heating component during summertime, but, we are blessed w/ long daylight then, too. Most of the indoor illumination is not required.
Good Answers: 146
02/01/2009 8:07 AM
Amen to critical thought. It's exactly the mentality of the "blanket solution" that gives rise to holier-than-thou nonsense, or huge environmental errors like subsidizing the switch to cultivating corn for energy on a massive scale.
Try wearing a leather jacket bought second hand and lasting for 20 years. "Green ignorance" is wearing a synthetic jacket that will have to be replaced every year or two years because they fall apart. Which one costs the environment? Notwithstanding the facts when you think it through and calculate, the wearer of the leather will have to bear the scorn of the righteous, who, lets face it, don't reason their actions and just want a set of rules they can follow without thinking.
incus opella
Good Answers: 103
02/01/2009 4:37 AM
Let us not think about legislation.
The big brother is watching, but I have certain concepts about politicians which can not be expressed in this type of forum.
End of the day, if we forget about the incandescent-CFL row, each brick has its own place in the building. We have to find the correct usage (Since I am managing manpower, that is the concept)
We should try to utilise the things as an when it is optimum.
Induction motors are better than Synchronous (there may be so many logics), but we have to use the Synchr under some usage.
What about ball Brg Vs SRB , or TRB Vs SRB (T= Taper, S= Spherical, RB = Roller Bearing for the uninitiated - the other member of the family being C=Cylindrical and also N= Needle , but not used as NRB but this is off the topic)
We talk of (in my one of the topics discussed about Green Fridge) CFC free apparatus. However while doing research (on net) I could not find the solution, but what I found was surprising
CFC - has an effect on Ozone (it is called OD gas)
the replacement is HFC or HCFC - No OD
But the GWP (Greenhouse warming potential) of Freon (CFC) was about 1600 if I remember and the replacement non OD was from 3600 to 4800
Now can we so confidently say that replace CFC with HCFC (as now all the politicians everywhere including EU are insisting on ?)
Good Answers: 80
02/01/2009 2:55 PM
I did the energy saving calculations a few months ago. Here are the rough results from memory:
For all the warm places using AC six months a year, CFL lamps save as much as 20-30 dollars over their life span if they don't fail early.
For a place where you heat 6 month a year, cool 2 months, you will get your money back from the CFL eventually but it is not worth the trouble if you prefer the warmth of the incandescent lights.
Arctic circle residents: Don't bother.
02/02/2009 7:42 AM
I live in a warm place and use CFL lamps.
Don't believe the life claims. I have had them fail in as little as a year.
I use daylight lamps when I can get them because I like the quality of the light and prefer it to the "warm white" incandescents give.
I think that is my main reason for using these lamps although they have made a small difference to my power bill. Air con dominates in summer, so the saving is quite small.
I must admit my family are slack about turning off lights when not needed. Doing this would make more difference than anything else.
The heat from the incandescents was not noticed, but in a cold climate it should make a small contribution, although in those conditions I suppose every bit helps.
When you do the sums, a bulb will contribute 100W while a CFL will probably contribute 20W, a net addition of 80W. This is minor compared to the 2KW+ which a normal electric heater will contribute. (I know, we have to use one about 5 nights a year, when the min temp falls below about 15C - we do get cold weather here)
Reverse cycle air con may be a more efficient heating solution.
01/17/2010 2:30 PM
I lived in the Fairbanks North Star Borough from 1990 until 2004. While I was living in my last house, 1997 to 2004 the CFL lamps became available. I had a 1300 square foot home, and I replaced all of the incandescent bulbs with the CFL's and my electric bill dropped about $25 a month, basically from $140 to $115. For exterior lighting I used incandescent flood lights. The makers of CFLs claim they will function down to -20F, but my experience is diminished lighting starting at +40F.
The following is off topic: I've seen periods in Dec through Jan where the lows would be -45 to -55F and the highs below -35F for 2 weeks. With temps below -40F, mercury light switches will not function correctly, either remaining on, or off till the temp comes up above -39F. BTW when the temperature is below -45F, one has to pour hot water on a propane tank in order to get enough vapor pressure for a cooking stove to work.
Popular Science - Weaponology - Ancient Weapon Enthusiast United States - US - Statue of Liberty - Viva la Revolucion!
Good Answers: 15
02/07/2009 9:07 PM
There are lots of GA's to this post already, I just wanted to throw the LED wrench into the mix. Run your incandescents in the winter to help your heater and then switch to LED's in the summer to help your AC since they only generate a minute amount of heat. Of course you have to be prepared to drop a wad of cash on them but they should last at least 10 years, more if you're only using them seasonally... and they come in shades of white that are less unpleasant then that lovely pulsing green fluorescent lighting we all know and... love?
Education is not preparation for life; life itself is education.
Register to Reply 12 comments
artsmith (2); hairlesssimian (1); marcot (1); sb (3); sceptic (2); sidevalveguru (2); WadeinH2O (1)
You might be interested in: Incandescent Lamps, Pressure Gauges, Pressure Switches
