Previous in Forum: API/5L-A PIPE MATERIAL   Next in Forum: Geothermal Valves
Single application of helical and spur gears
01/31/2009 7:31 AM
what are the common applications in which both helical and spur gears are simultaneously working? how?
Paresh B. Gujarati
Good Answers: 103
Re: Single application of helical and spur gears
01/31/2009 7:42 AM
Multi stage reduction
01/31/2009 9:55 AM
Shame SB. You only get partial credit - you did not answer how. I hope you (both) do better on the exam.
Good Answers: 103
01/31/2009 11:24 AM
please design the gearbox for me
help it is for my project work. Also enclose the material for each parts, dimensions, bearings and all the load calculations.
09/10/2009 5:25 PM
How about a 1934 ford pickup..( or any stick shift that suits your fancy?... tranny and differential. MR GUY
If you are looking for a positive answer..it's YUP......
Location: N.E. Alberta 55.6329 N Lat. 111.0729 W Long. Canada
01/31/2009 5:18 PM
A lathe has these types of gears in some of them. Helical to drive the chuck and spur gears to run the feeds. Automatic transmissions have a helical gear on the sun gear and spur type gears on the planets and carrier. Different manufactures of gear boxes have this type of setup, whether for speed increase or reduction. Depending on the load. Some spur gears run off the main drive to power accessories.
Could be worse, it could be me. :)
02/02/2009 3:49 AM
You will see this often in wind turbine gearboxes. The planetary stages have spur gears because these are easier to assemble plus the low stages are considered not that critical on noise. Also, for planetaries, using helical gears would mean an introduction of increased planet gear tilt which makes these gears critical to edge loading. To counteract that you would have to apply expensive countermeasures like for example flexible planet pins. On the high speed side however (for non planetary high speed stages) noise is more an issue so helical gears are often used to increase the (axial) contact ratio which smooths the running characteristics of these gears, as a bonus it also increases the load carrying capacity of these gears slightly. This however has consequences for the bearings supporting these gears as they have to take a higher axial load so the amount of helix is always balanced out to optimise performance of both bearings and gears.
'There is no such thing as a silly question, only silly answers' - Unknown
02/02/2009 3:56 AM
It is considered impossible for a planetary gear train with gears meshing with each other to have both zero and non zero helix angle at the same time, unless you are talking about helix errors or lead profile modifications but I don't think the initial question refers to that.
Register to Reply 7 comments
Dutchy (2); mayt2u (1); Mr. Guy (1); sb (2); TexasCharley (1)
You might be interested in: Metric Gears, Spur Gears, Helical Gears
