Previous in Forum: Gear Box   Next in Forum: vacuum type dp transmitter calibration
4-20mA
02/01/2009 7:43 AM
why we use 4-20mA range in current o/p or i/p. what is the reason for calibration zero at 4mA and span for 20mA
Re: 4-20mA
02/01/2009 8:02 AM
This question was just asked and answered a few days ago.
If you look to the right, you'll see a "search this forum" window. Type your question in there.
Re: 4-20mA
02/01/2009 5:06 PM
Don't feel bad hiteshpurani, I cant find it either
Re: 4-20mA
02/01/2009 6:33 PM
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
Re: 4-20mA
02/02/2009 8:41 AM
Hit the link, it will tell you the answer.
Money doesn't talk, it screams in your face.
Re: 4-20mA
02/02/2009 11:36 PM
4-20mA range in current is used , since this range allows to transmit the signal effectively and also keeps the instrument device safe from any explosion/destruction.
in case if calibration is done at zero and a problem occurs in the device or the wiring it will not be detected since the system will assume that the instrument is working fine and showing 0mA thus to avoid this situation calibration is done at 4mA , since incase if the value goes below 4mA the system can detect the device is malfunctioning or there is some error in the reading
Anonymous Poster (2); betomachine (1); lyn (1); michelle2480 (1)
