I forgot my password.
Don't have an account?
I did programme the micromaster with siemens software but it is not working both the LED's are lit, not getting out put.
hi,
go back to the micromaster operation manual which is very clear for trouble shooting and to start. if you still find problem let me know.
hi....
my name is najmul from malaysia...
i need your help.
i already installed motor specs & follow the operating instruction. However, when i trial run the inverter, it operated.nevertheless, i were not connected to motor supply.
When i checked voltage output at the inverter, multimeter shown nearly 750V.
So, i would like to know why this is happen?
My spec
Input volt to inverter = 240 V
Output Inverter = 415 V
Motor spec
415 V, 1.5 A, 1410 rpm, 50 Hz,
