Previous in Forum: Small Gas, LPG, or Diesel Turbine Generator   Next in Forum: Diesel Tank Designs
Calculating Air Pressure Loss
02/02/2009 8:29 AM
how to find the pressure Loss for air line?
Pipe Material is A53 Gal.
Sch. 40
Pressure is 4bar
Pipe size 4" inch
Good Answers: 266
Re: Pressure Loss calculation
02/02/2009 9:02 AM
4" is a good size pipe in order to have a pressure loss would to be using a lot of cfm's.
In order to calculate the loss would need to know what the cfm's are.
Re: Calculating Air Pressure Loss
02/03/2009 11:28 AM
To do it "from scratch" there will be examples of this in any fluid mechanics text book. It of coarse involves the Reynolds number. You would need the right prerequisites to understand the material.
Many "typical application" tables or algorithms exist such as the good one referenced in response two. They work well when used as intended.
Everything I know about opera I learned from Bugs Bunny
Register to Reply 3 comments
Anonymous Poster (1); DaveB (1); ozzb (1)
