I've had this problem on a desktop, I hit the power button and got no response whatsoever. After changing out the power supply, everything worked great. If you are a DIY'er then try seeing if you got power out of the leads from the power supply. Usually if a power supply goes bad, all the leads don't go bad, just a few of them.
Else take it to a repair store and get charged up the wazoooo. Power supplies are cheap but labor isn't....
