Previous in Forum: differential gear   Next in Forum: 2006 GMC Sierra - Sunroof Stopped Working
2001 Mitsubishi Galant - Engine Cool Down
02/04/2009 11:50 AM
my brother owns a 2001 Mitsubishi Galant and the problem is once he cuts the car off it wont run again until the engine completely cools down and sometimes it cuts off while driving. we initially thought it to be the fuel pump so we replaced the pump, filter, and screen but the problem still persists. what might be the problem and how can it be fixed?
Pathfinder Tags: engine fuel galant
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: my brothers car
02/04/2009 1:41 PM
This sounds potentially computer related. Perhaps one of the engine temp sensors is bad.
This would be a good time to check or have them checked.
Another possibility is a plugged catalytic converter.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Good Answers: 123
Re: 2001 Mitsubishi Galant - Engine Cool Down
02/04/2009 6:02 PM
Have some one read the computer's memory of trouble codes. Don't guess, diagnose.
Bob
02/04/2009 6:18 PM
Good catch Bob,
I guess I didn't proof read.
Hobbies - Car Customizing - New Member
Good Answers: 11
02/05/2009 12:05 AM
that's an OBD2 car (on board diagnostics gen2)
a scan tool can read history codes and data stream
you should be able to determine what's missing.
a data logging function is available as well
Prob a weak sensor or ignition componnent heat soaking
02/05/2009 2:25 AM
I had the same problem with my ford lynx before..engine will stall suddenly..I brought it in for service, replaced fuel filter and still had the same problem..until they checked it with their computer and found out that the Intake air temperatre (IAT) sensor is the culprit.
bob c (1); ericpolc (1); Shadetree (2); Yosemit3 (1)
