Previous in Forum: How to select the boiler drum lvl transmitter?   Next in Forum: Calibration Calculations
Valve Benchsets
02/05/2009 6:39 AM
hi friends,
how to change the benchset in the valve, how to select the characteristic of the control valve.... if any one have idea about this post ur comments
bala
South Africa - Member -
Good Answers: 12
Re: Valve Bench-sets
02/06/2009 12:46 AM
Hi there,
This has been answered in many threads before.
If you have studied you will know how to select the characteristic of the valve - you need to know your process characteristic as this determines your valve characteristic. Is the process linear; =% etc etc? This is not an easy thing to explain - use google and you will find your answers.
Playing with your valve stroke zero and span limits as well as your positioner zero and span limits will change the valve bench set - I am not sure if you know what bench setting a valve means?
When we ask for the valve to be bench set - we are asking for the valve stroke as well as the positioner to be pre calibrated to a certain range i.e. 100% stroke equates to a 4 - 20 mA signal from DCS to a 20 - 100kPa signal from I/P to positioner - to x - y on the actuator.
Please refer to the manufacturer documentation and you will get your answers.
Somehow this sounds like a question from some homework paper?
Regards,
Craig
Good Answers: 103
02/06/2009 7:10 AM
I too thought so, then I checked up OPs previous posts (thogh only 2 ) and they didn't look like homework (especially the post #2 which was off topic)
May be a green horn in a power plant.
Register to Reply 2 comments
