Previous in Forum: Non-Conformance Costs in Turbogenerators   Next in Forum: Induction Motor Load Tester
Alternative to Bentonite?
02/06/2009 3:27 AM
what is the alternate of bentonite to fill in earth to get less resistance
Pathfinder Tags: earthing
Re: Alternative to Bentonite?
02/06/2009 9:54 AM
Depending on the geology of your site and the water tables, look at electrodes encased in concrete. This is one of the many methods described in the IEEE Green Book on Grounding Electrical Systems. Probably the best thing to do other than that is to talk to any vendor/contractors in the area that are doing Lightning protection. They will have a pretty good idea of what is required for the area. Concrete encased is about the simplest method outside of standard driven rods. Hope this helps.
Joe the Electrical Contractor to the EOR, I know it was suppose to be in my base bid, but I still am going to submit a change order for it.
Good Answers: 40
02/09/2009 8:59 AM
As this is not an issue in the subsea (cathodic protection) environment, I haven't had to commit such tidbits of trivia to memory... but I have seen numerous such threads on the NACE Corrosion Network among land-based pipeliners.
Go to the NACE website, and click the "Resources" links to get to the Online Community page. There you can sign-up for free, to gain access to experts all over the world. There's also an archive of previous discussions that can be searched.
A plethora of information there. Worth the dig...
Best wishes in your endeavors ~
Engineering Fields - Systems Engineering - Member for some time now, see my profile.
02/09/2009 4:34 PM
From Sleepy,
We used to utilise Marconite as a filler to make concrete conductive.
There was a recent post which had details of where it could be obtained from.
My experience was as Systems Manager of the group that came up with the concept.
Designer: William (Bill) Hymers
Long term tests were conducted - essentially to produce conductive buildings for screening and lightning protection.
Good Luck
Sleepy
12/15/2009 8:58 AM
Dear friends
Please see following links to understand What is earthing in electrical system
http://picearthingtech.com/
http://blogs.siliconindia.com/picearthingtech
Regards
Raju
Earthing is important but neglected
Register to Reply 4 comments
Electron Plumber (1); ndt-tom (1); Sleepy (1); Tamakuwala (1)
