Previous in Forum: Alternative to Bentonite?   Next in Forum: transformer
India - Member - moorthi
Induction Motor Load Tester
02/06/2009 4:00 AM
dear friends;
I need a ac induction motor load tester to test load current, rpm and torque.
can you give me simple mechanical diagram for it.
Thanking you
moorthi
Good Answers: 42
Re: induction motor load tester.
02/06/2009 9:04 AM
Hi Moorthi,
A simple tong tester ( clip on ammeter)can measure the load current, a simple portable tachometer can measure the speed and a simple portable digital torque tester can test torque. What mechanical drawing is needed for these simple meters? . If you are having a motor manufacturing unit then all these meters can be assembled to a custom made panel.
Good Answers: 25
Re: Induction Motor Load Tester
02/07/2009 4:07 AM
Hi Moorthi,
You will need Dynometer to test load. It is availably in the market. For other tests Mr. Abhram has already replied you.
02/07/2009 8:58 AM
The simplest one is the Prony brake.
Aged man is not old man...
Register to Reply 3 comments
Qqberci (1); suresh sharma (1); V.I.Abraham (1)
