Previous in Forum: Delta Connection   Next in Forum: Shell to Roof Junction
Bending Radius for steel Pipe
02/06/2009 6:13 AM
an application in my industry calls for 90 degree bend of 1" sch.80 pipe &
as we know a steel pipe can be bent for 90 degree,but wht is the minimum radius need to be maintained at the bend and why is it so, is there any stand or formula govening that minimum radius at bend??
Re: Bending Radius for steel Pipe
02/06/2009 1:31 PM
5 times the outside diameter is pretty common
Good Answers: 51
02/06/2009 3:23 PM
It depends on the pressure drop allowed from a fluid perspective.
And from a code perspective it depends on material, thickness, type of bending performed (hot/cold), maximum fiber elongation, and ultimately any heat treatment required.
For reference please see Sec. 332 of ASME B31.3
A little knowledge is a dangerous thing.
Indonesia - Member - New Member
10/03/2014 3:07 AM
If your pipe will operate to belonging to ASME B31.4 (liquid) or ASME B31.8 (gas), there mention allowable radius. From that value you can draw or calculate, to get allowable degree.
Thanks
Anonymous Poster (1); AvatarIndo (1); XMech (1)
