Previous in Forum: Feasibility Studies for Plant Design   Next in Forum: Boiler Flow Direction
Regular vs. Type X Drywall
02/06/2009 11:31 AM
Are there any visible means of knowing if you are looking at regular drywall or "Type X" (fire rated) drywall--are they labelled or something?
Good Answers: 38
Re: Regular vs. Type X Drywall
02/06/2009 12:20 PM
Depending on where it was made may give you a clue. Fire rated is made with mixing a non combustible fiber with the gypsum. Unless you can easily see the gypsum (hole cut for receptacle) and actually see the fibers it's very hard to tell what type it is. Even this may not help. If it is new and still stacked and held together with the tape, it should state the rating or have a brand name on it.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
02/10/2009 11:36 AM
Thanks,...sorry to hear that.
Good Answers: 101
02/06/2009 2:30 PM
If your looking at new sheets it should be printed/stamped on each sheet somewhere. If its already installed/papered over/plastered/painted, it might be a bit harder.
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
02/06/2009 8:52 PM
Most drywall is inherently fire retardent due mostly to the fact that gypsum turns to water (or rather expells the water in it) when heated to suficient temperature. That is why if you need more fire protection you should put up thicker drywall.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
02/07/2009 3:14 AM
It all depends on the manufacture, thickness, age, and condition of the drywall. if it is 1/2" type X it will be stamped on the factory ends of the sheet. the best "ruel of thumb" is if it is 5/8" drywall it is type x. but with 1/2" you will have to look at the back side of the sheet if you can't see the factory "bevels" on the sheet.
Anonymous Poster (2); charsley99 (1); RVZ717 (1); Shadetree (1)
