Can some one explain me what is the Induction Lighting system? How it Works? What are the types of Lamps? Is it requires Magnetic Ballast or Electronic Ballast or Electronic Circuit?
An induction light is similar to a fluorescent light in that mercury in a gas fill inside the bulb is excited, emitting UV radiation that in turn is converted into visible white light by the phosphor coating on the bulb. Like fluorescent, the phosphor coating determines the color qualities of the light. Fluorescent lamps use electrodes to strike the arc and initiate the flow of current through the lamp, which excites the gas fill. Each time voltage is supplied by the ballast and the arc is struck, the electrodes degrade a little, eventually causing the lamp to fail. Induction lamps do not use electrodes. Instead of a ballast, the system uses a high-frequency generator with a power coupler. The generator produces a radio frequency magnetic field to excite gas fill. With no electrodes, the lamp lasts longer. Induction lamps, in fact, last up to 100,000 hours, with the lamp producing 70% of its light output at 60,000 hours. In other words, their rated life is 5-13 times longer than metal halide (7,500 to 20,000 hours at 10 hours/start) and about seven times longer than T12HO fluorescent (at 10 hours/start).
