Previous in Forum: Induction Lighting system   Next in Forum: Electrical Load demand calculations
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Invisibility Cloak Made To Measure
11/03/2006 8:38 AM
Theoretical physicists in the U.S. and UK have proposed a method of rendering objects invisible. Their work suggests that if an object is shrouded in a material with a negative refractive index, light from behind the object would pass through the material and flow around the object like river water around a rock.
Good Answers: 120
Re: Invisibility Cloak Made To Measure
11/03/2006 11:48 PM
doomed to fail at visible light frequencies. Can be made to work at microwave frequencies
Per Ardua Ad Astra
11/04/2006 7:58 AM
In reading the article, I am left with the impression that any objects that this would be used on would need to be of a certain shape. How would this allow the principle to be applied to objects of other shapes?
See Bio for signature line........political correctness and insecure people are such a pain-in-the-ass.
Good Answers: 16
11/14/2006 7:28 PM
If only microwaves are affected in would still be of interest to defence forces as microwaves are often used for targeting. The article only speaks of being back lit by the radiation, I wonder how it would work for reflectivity?
Make it so.
Good Answers: 120
11/14/2006 10:42 PM
I suspect this method will find use in target spoofing in the microwave area. Shift a target a few feet to a radar eye view and something may miss a target, which is good if we are the target and bad if the enemy can shift his perceived position.
There is nothing new in this concept, from WW2 when 'window' was used to dominate early German radars with false echoe.
Since then radars have gone up freuqncy and up agile, but there may well be a way in these to spoof.
Per Ardua Ad Astra
Register to Reply 4 comments
aurizon (2); BlueAussieBoy (1); water buffalo (1)
