Is there any thumbrule/ calculation for HAZ in a welding (say carbon steel) vis a vis the chamfer size in a butt weld ? I know about the heat input in weld and its calculation, but calculation it from there to the HAZ size seem to be laborious and complex.
Problem: There is an application where a shaft is having a flange. Current design is carbon steel forging. The shaft is very heavily loaded (with medium to low freaquncy high amplitude fatigue cycle). The shafts of this type are known to fail in operation in case of compromises/ overlooks (eg un-identified surface/subsurface defects)
As part of cost cutting there is a proposal to convert it into fabrication with a Rod and a Plate as shown.
The question is
a) As my knowledge goes there is a fatigue strength reduction in the HAZ. and in this case it being on the highest stress portion may to shaft failures (at least a few of them). This is not acceptable (even at the cost of cost cutting
b) The possible welds are K - to keep the less HAZ on shaft side, X to have equal weld or U/ Double U) or half of it - don't know what it is called
b) So how far should the weld move away from the notch to avoid this problem.
c) In especially 2nd case the NDTs will not be much reliable since even X-ray will not very reliably pick up the defects. And for this application I am not sure the X-Ray sensitivity will suffice or we have to go for UT additionally. (Of course the mandatory MPI/LPI will be done after machining it)
PS: This is not a repair shaft and a part of OEM so here the equipment/ design can not be compromised.
