Previous in Forum: 1996 Honda Accord 2.2 SV4 - Gearbox   Next in Forum: Lithium Cobalt Battery
Strange
02/08/2009 3:52 PM
Hello, I need some help, my 1999 Chevy Cavalier is starting to shake very badly, but only when I do not have my foot on the gas or the brake pedal? What would be causing this because it is making me very nervous to drive it...Please someone have an idea as to why that might be...
Re: Strange
02/08/2009 5:05 PM
It needs a tune up.
Re: Strange
02/08/2009 6:05 PM
Bad/loose front end steering parts. Whenever you accelerate you are increasing the frictional force on the front tires driving them backwards. The same is true when you brake. If your tires (in terms of toe-in/toe-out) are straight || then when you brake or accelerate the force will try to push them \ /.
If any components in the front end are loose or worn, it will have a tendency to "shimmy".
Take it to a reputable mechanic and have them check the tie rods, ball joints etc...
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
Re: Strange
02/08/2009 6:33 PM
Where do you feel the shake, in the steering wheel or in the seat?
Does this car have an automatic or manual transmission?
Is there any noise that goes along with the shaking, such as a clicking or clattering?
Are there any other noises, such as a grinding or scraping when the brakes are applied?
Answers to all the above will help to pinpoint the problem but it sounds like a trip (or maybe a tow) to a good auto repair facility is in order here.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
Re: Strange
02/08/2009 11:48 PM
strange; pull the hub caps & check if the nuts are lose, or the whee(s)l has oblong slots. perry
Kilowatt0 (1); lyn (1); perry (1); Shadetree (1)
