I have a Philips 32pw6006/25 32" wide screen TV CRT. I have had the back off and looked at it with a mate and we both think it could be the flyback trasformer.
There is a high pitched chirping noise that you can't quite figure out where its coming from once you turn on the main switch. The unit doesn't even go into standby mode or even let the power LED turn on.
Previously to the TV not working it used to take ages to warm up and keen turning off to stand-by mode and the right side of the TV would wobble till it warmed up then it would be ok.
the flyback transformer is only about £25 so its not the ned of the workld if the tv doesn't work after wards but is it likly to have taken anything elese out when it died that we should look for ?1
