Previous in Forum: Three Switches, Three Lights, and Some Relays   Next in Forum: Flyback Transformer for Philips Widescreen TV
9 comments
ac motors
02/09/2009 9:01 AM
What happens if the supply lines are connected wrongly
Re: ac motors
02/09/2009 9:16 AM
Depends on what motor and configuration! Is it a 3 phase, single phase, star/delta start up, cheesie little 12Vac, Big brutal monster of a motor...etc...We need more info, and I don't mean 'yes, it's big!' either!
Re: ac motors
02/09/2009 10:47 AM
I'm talking of a 230V 3-phase delta connection (up to1200rpm, 0.75kW)
Suppose the feed lines cannot be identified, will there be any harm caused to the motor if Line 1 is connected to the W terminal,Line 2 to U terminal and Line 3 to V terminal (as oppossed to 1 to U, 2 to V and 3 to W) even if the motor runs in the desired direction?
Good Answers: 18
Re: ac motors
02/09/2009 10:05 AM
If it's 3 phase, it will run backwards if connected wrongly. If it's single phase with two leads, then it will run correctly. More info needed otherwise.
Re: ac motors
02/09/2009 10:48 AM
Good Answers: 18
Re: ac motors
02/09/2009 10:49 AM
Nope -- just switch two of 'em.
Re: ac motors
02/09/2009 11:03 AM
Thanx!
I was worrying it might cause overheating
Good Answers: 137
Re: ac motors
02/09/2009 11:27 AM
Hello Guest - yes, we've got the message by now!
Cheers.......Codey
Re: ac motors
02/09/2009 10:41 AM
Good Answers: 103
Re: ac motors
02/09/2009 11:34 AM
Don't run for long in reverse direction case the motor is not bidirectional (some times the cooling fan behind is not bidirectional)
Also the motor if connected to a pump may cause the pump to seize.
The usual procedure we follow is On/OFF and check the direction of rotation.
However if the motor runs in correct direction why bother (in time phase there is no RBY they are unifirmly distributed at 120 deg phase shift, and when in a circle one is behind other who is first ? a la in the second orbit around atom (classical theory not spdf orbitals or electron clouds ) of 8 electrons any one can be first , others wrt this are 2nd 3rd etc.
Anonymous Poster (4); Bill (2); Codemaster (1); Mr. Truman Brain (1); sb (1)
You might be interested in: AC Motors, DC Motors, Stepper Motors
