Previous in Forum: Electric Motor Efficiency   Next in Forum: Isolator Switch Rating
8 comments
Fault Current Ratings
02/10/2009 11:22 AM
Guys, I'd like to know how to calculate the max fault current for an 11kv transformer if one knows that the power output is 10.9mVA?
Elp.
Pathfinder Tags: Fault Current power
Good Answers: 18
Re: Fault current ratings
02/10/2009 11:28 AM
What's the transformer impedance? I = V/Z
Fault current ratings (as in NEMA, NEC, ASTM, NFPA or UL) are one thing, and actual fault currents (hopefully less than rating) are another.
02/10/2009 11:53 AM
Wow that was quick! I was going to assume 80% of max 'nominal' fault rating as a likely fault but how to calc the max fault to begin with?
Is there a 'typical' impedance value one can use as an assumption..... 5% Voltage?
Re: Fault Current Ratings
02/10/2009 12:44 PM
You need to find the multiplier for that transformer. Take 100/%Z of the transformer. Then to find the maximum available fault current on the secondaries of the transformer, multiply the full load rated current of the transformer by the Multiplier above. In other words the multiplier for a 5% transformer impedance would be 100/5= 20. So the maximum fault let thru current (based upon an infinite bus on the primary) would be the FLA X 20. Best source to read up on this is the Bussman handbook.
Joe the Electrical Contractor to the EOR, I know it was suppose to be in my base bid, but I still am going to submit a change order for it.
02/11/2009 3:46 AM
So, is it....?
1.732 / V (11kV) / 10.9mVA = 572A as its working load..... then x 20 = 11.4kA max fault current
Assuming a 5% impedance (100/5=20). It looks about right.
Good Answers: 18
02/11/2009 9:00 AM
Consult "Ugly's" page 51
02/11/2009 9:35 AM
Hi GHOG,
'Ugly's?? unfortunately, I don't have a copy....what is it?
Excuse my ignorance, I'm a mechanical bod who has been forced to dabble in this stuff that you can't see...called electricity!!...nasty stuff with loads of calcs every left, right and centre!!!
Good Answers: 18
02/11/2009 9:45 AM
Ugly's Electrical Reference
Burleson Distributing Corp.
3501 Oak Forest Dr
Houston, TX 77018
800.531.1660
www.uglyselectrical.com
02/11/2009 10:02 AM
Thanks ol' goat, I'll pop an order into amazon.
Register to Reply 8 comments
Bill (1); Electron Plumber (1); GRAY HAIRED OLD GOAT (2); user-deleted-1092 (4)
