Previous in Forum: The Best CNC Machine for Doors and Cabinets   Next in Forum: sapphire crystal
10/24 roll form taping in steel
02/10/2009 12:32 PM
I am having trouble with a production job that we are trying to tap a series of 10/24 hole in steel. I am using ti coated bottoming taps, drilling @ .172. to .174 There is plenty of clearance for tap. I currently get about 120 hole per tap and then the taps need changing, due to the minor dia getting large. Drills do hold consistant size.
We are using coolant.
Any ideas
Kevin
Re: 10/24 roll form taping in steel
02/10/2009 1:27 PM
How deep is the cut? Are you using a slow sprial tap? If so, you may want to try a fast sprial tap to remove the chips faster and maybe you'll get less wear..
02/10/2009 2:16 PM
thanks for the responce. I am roll forming. So no chips are formed.
Kevin
Reply Off Topic (Score 4)
02/11/2009 11:58 AM
Sorry i didn't catch that in the title.. my bad.
Good Answers: 103
02/11/2009 8:24 AM
The drill diameter is OK in fact slightly on higher side (recommended for 10-24 is 0.170-0.174). Do you check the holes (tapped) with Thread gauge ?
When the dia is getting enlarged is thread as per gauge still OK ?
I suspect the major dia (the forming edge) is wearing out and that is not generating enough metal flow.
Check the suitability of material with ref to the forming (may be high tensile/ hard material ? ) that case anyway you are likely to have less tap life.
Since in this small size, you can not experiment with through the tool cooling , try to experiment with coolant. Did you try cutting oil ? it may help in better conductivity of the generated heat and the higher viscosity may improve the lubrication.
02/11/2009 9:36 PM
Your best bet is to directly contact the tap manufacturer for advice. They may have a different tap design or coating more compatible with your specific requirements.
02/23/2009 7:20 AM
Bottoming taps are made just for that bottoming. They are not designed to tap a complete hole from top to bottom, they are made to get the last few turns at the bottom of the hole.You need a gun tap to go as far as you can then use the bottoming tap preferrably after the hole has been cleaned out.You could also try a roll forming tap as there will be no chips to worry about.
Labyguy (2); mtdmaker (1); pantaz (1); sb (1); snowrunner51 (1)
You might be interested in: Taps, Threading Dies, Stainless Steel Alloys
