Previous in Forum: POSITION INDICATOR   Next in Forum: Cooling Tower water consumption
Ducted Air Compression
02/10/2009 12:53 PM
Low preasure air moving through a duct will speed up as the duct narrows, as when passing through a funnel. Is there an optimum funnel angle to do this, does the angle change w/ air density and/or preasure, is there a formula for this? This is being applied to a nacelle on slow moving (50 mph) research aircraft at 20-30,000 ft. this is not my homework, Im just an inventor. thx Spacecannon
The person who wrote the above is not resposible for spelling, grammar or puncuation, ......
Re: Ducted Air Compression
02/10/2009 6:15 PM
Turbulence is your biggest enemy. Smooth transitions are best, generally, and don't forget to leave the last 3/5 duct diameters straight to calm the flow.
At these low velocities/high altitudes a square transition and longer tube may be as efficient.
Didn't catch the duct diameter.
I'm sure the formulas will be forthcoming.
I don't do math.
02/10/2009 6:53 PM
thx LynLynch, open end diameter is apx. 30m on the smaller unit and 100 meters on the big one, lengths are 7-10 times the width, I also need to calculate how small I can neck the funnel down to w/o significantly reducing air flow.
02/10/2009 11:43 PM
Sorry,
I really don't do math that big!
Register to Reply 3 comments
