Previous in Forum: Medium Voltage Bus Ducts   Next in Forum: How to test the polarity of a CT
73 comments
Quick Electromagnet Question
02/10/2009 7:03 PM
Hello All!
I have a 24V 24A DC power supply that I am trying to hook a 50 loop electromagnet using 22 gauge non insulated copper wire and a small steel nail. Every time I hook the electromagnet to the power supply it sparks and Humms. So I put a 220 ohm resistor inline and it did not spark but there was almost no magnetic field strength. When I hooked my electromagnet to two D batteries that I tapped together using electrical tape the magnetic field was SOOO much stronger than when I hooked it up to the power supply. What?!? That shouldn't happen. It should be the opposite. What am I doing wrong? Is there something else I can put inline besides the resistor so that the magnetic field will be strong? I really want to use the power supply to power the electromagnet. How can I make this work???
Thanks everyone.
Stephen
Re: Quick Electromagnet Question
02/10/2009 7:35 PM
You haven't given the dimensions of the coil, so we can't work out the length of wire (& hence calculate the resistance). Can you measure the resistance, or tell us how much wire there is?
Remember that batteries can provide a huge current (for a short time).
Your PSU should be able to give you the 24V @ 24A with a 1 ohm load. Assuming your coil is somewhere around 1Ω, putting 220Ω in series will leave you with 0.5% of the power for your magnet (or looking at it another way, you'd have a maximum of 24/220 ≈ 110 mA going through the coil).
If your coil is appreciably less than 1Ω, it's no wonder your PSU is complaining.
BTW - you realize you've got ½kW of power available there? That coil will get pretty hot! Suggest you work out wire size & number of turns to give, say, 20Ω, bringing the heating power down to a more manageable 28W.
Good Answers: 88
02/10/2009 7:55 PM
Hi Stephen,
Your electromagnet attempts to draw more current than your power supply can provide and so the supply drops out of regulation. Some supplies also have a feature called a "crowbar" circuit which shuts down the supply's output stage when conditions stress it beyond its limits. Your electromagnet will definitely stress this supply.
I'm guessing that you've got around 40" of 22 AWG enameled copper wire in your electromagnet. 40" of 22 AWG wire has a resistance of around 50 or so milliohms. At three volts across the magnet, a suitable power supply would have to provide 60 amps to maintain that voltage. 'D' cells cannot source this much current because of their internal resistance (IR), but they can source more current than a crowbar'd power supply. A typical 'D' cell's IR is around 100-300 milliohms, which limits the current it can supply to some value between 5 and 15 amps. You can be sure that the voltage across the battery is not 3 volts during this time, but the battery is still pumping out a lot of current, and it is the current and the number of turns that determine the strength of the magnetic field. Apart from its role in pushing the current through the magnet, the voltage makes little difference.
My suggestion would be to either use a fresh lantern battery or add another 800 or so turns of wire on the coil if you want to use it without your 24-volt supply going south on you. Construction will be a problem with this many turns of 22 AWG wire, so you might try using a smaller gauge. Say, 28-30 AWG. A smaller gauge means a higher overall winding resistance for the same number of turns, plus the windings are more tightly packed.
02/12/2009 11:06 PM
But if it is enameled, it wouldn't make contact with the battery, and no current would flow. If he had scraped off the enamel, he would know it was insulated!
Good Answers: 88
02/13/2009 9:17 AM
Well, it is obvious he made contact somehow. Why don't we ask the OP for clarification?
02/13/2009 1:17 PM
He's not replying. Let's assume he is right. A shorted out winding will produce a magnetic field approximately the same as a straight piece of wire will.
Good Answers: 88
02/13/2009 1:31 PM
Sure it will, but given the limitations of his power sources he would not have observed that "...the magnetic field was SOOO much stronger...," in his words. His 'D' cells will source only 5-15 amps, max, because of their internal resistance, and a single turn at this current would not produce a strong field; much less a "SOOO much stronger" one.
This is an easy experiment to duplicate. Why not give it a try?
02/13/2009 1:46 PM
Are you hearing voices? The author said nothing about a HV supply, and did not say 5-15 amps either. I have made electromagnets in the past using batteries. I do not believe D cells are limited to 15 amps. Try it yourself.
Good Answers: 88
02/15/2009 7:14 PM
I hear voices all the time. You were saying...?
02/15/2009 6:15 PM
Thanks guys for all of the posts. I thought it would take much longer for anyone to answer. After I read your comments about magnet wire being insulated, I went back and made sure that the wire I was using was uninsulated, which it was. So I'm going to radio shack tomorrow to pick up some magnet wire and a few resistor ranging from 5 - 40 ohms.
Thanks again.
Stephen
02/15/2009 7:05 PM
"I thought it would take much longer for anyone to answer ..."
You posted 4 days ago. On CR4, a hot topic gets folk twitchy if there's no reply in 4 minutes!
The fact that you managed to get a reasonable electromagnet working using a couple of D cells suggests you were lucky enough to have either some nice, evenly spaced turns in your coil together with a very dirty nail, or some very dirty wire.
Check out the resistance per unit length of the (insulated magnet) wire, and put enough on the nail to get you up to about 20Ω.
If your supply is adjustable, crank it down to just a few (2 or 3) volts, to bring the power down. This would save chucking away a lot of power in the resistors.
Remember that:
1) power = volts X amps (and ½kW will make things very hot).
2) adding resistors in circuit will be wasting power.
3) the resistors will have to dissipate power (as heat) - P = V2 / R, or I2 X R, or I X V. Even with 40Ω, you could be looking at (242 / 40) ≈ 15W, which is going to get pretty warm (you'll need to get power resistors).
Good Answers: 88
02/15/2009 7:43 PM
"The fact that you managed to get a reasonable electromagnet working using a couple of D cells suggests you were lucky enough to have either some nice, evenly spaced turns in your coil together with a very dirty nail, or some very dirty wire."
Hi John,
My thoughts exactly. Were the turns shorted, the current through the bulk of the coil would travel parallel to the nail and the magnet would not exhibit the kind of pull the OP described.
"Check out the resistance per unit length of the (insulated magnet) wire, and put enough on the nail to get you up to about 20Ω."
The OP may wish to use a smaller wire gauge for his next magnet. 22 AWG wire has a resistance of 16.2 ohms per thousand feet. For $6.59 Radio Shaft Shack sells a magnet-wire set containing three spools: 40 feet of 22-gauge wire, 75 feet of 26-gauge wire and 200 feet of 30-gauge wire. 200 feet of 30-gauge wire would put him in the ballpark of 20 ohms or so:
40 feet of 22-gauge wire @ 16.2 ohms/kft: 0.65 ohms
75 feet of 26-gauge wire @ 40.8 ohms/kft: 3.06 ohms
200 feet of 30-gauge wire @ 103.2 ohms/kft: 20.64 ohms
I would also urge the OP to contact an electric-motor repair/rewinding shop in his area for wire. Oftentimes these folks will sell "spool ends" of a desired gauge at or below cost. I've gotten quite a bit of magnet wire using this route and it's always been good, industrial-quality stuff.
02/16/2009 3:19 AM
If more windings increase resistance, then how can increasing the number of windings increase the magnetic field strength? I know for solenoids B= μ0 * n*I where n = N/L. But I= V/R so as the resistance increases as the number of windings increase then using I=V/R the current decreases. So why does the magnetic field strength increase when the number of windings is increased along with the resistance?
Thanks for explaining.
Stephen
Good Answers: 88
02/16/2009 7:51 AM
The objective is not one of increasing the magnetic field, but of increasing the magnet's operating voltage.
02/16/2009 12:00 PM
We design coil for our relays and see that you have been given some good answers along with some confusion (hope you can separate). To answer your question: each added turn adds both field strength and resistance (which decreases current). At the beginning, each turn adds more field strength than the small decrease in current subtracts. As turns are added, eventually you will hit a peak diameter and field strength, after which each longer turn will subtract more current and field strength than the turns will add.
If you want to keep the 24V supply and not burn your windings up, I suggest you keep the total power around 3W or less (resistance > 192 ohms @ room temp.). There are many possible solutions based on the size of the nail. For example, the maximized field strength for 2" long of windings in a 1/8" diameter nail would be about 7300 turns of (.005 dia. & .423 ohms/ft) #36 magnet wire (to about a .360" dia.). You could replace any fraction of the winding resistance (and volume) with a properly sized power resistor in series with the coil windings, but you will also decrease the field strength by the same fraction. For example, adding a 96 ohm resistor would cut the field strength in half and you would wind only 3650 turns in 1" long X .360" dia. & reduce the field strength by 1/2.
You could use a higher AWG than #36 with fewer turns to achieve the 192 ohms total, but the thin magnet wire would be difficult to wind by hand without breaking.
Have fun!
Good Answers: 88
02/16/2009 12:52 PM
"At the beginning, each turn adds more field strength than the small decrease in current subtracts."
Because at the beginning, the coil has the smallest circumference and so has the greatest dB/dR (change in field strength vs change in resistance), yes?
"As turns are added, eventually you will hit a peak diameter and field strength, after which each longer turn will subtract more current and field strength than the turns will add."
At a constant current through the coil, each turn will add to the overall field strength regardless of the net resistance. However, the voltage across the coil will increase in proportion to this resistance provided the current remains constant.
But, as relay coils are typically "voltage mode" devices, at some point the increasing resistance will decrease the current (and therefore the field strength) faster than the increasing number of turns will add to the field strength. It is where these two rates intersect that determines your optimum coil size, yes? This is assuming the larger coil does not "leak" field lines, which is typically not the case in practice.
Would you please show these design relationships here, on this forum, considering that you actually design these things for a living? We can derive the optimal point from a purely theoretical perspective, but in practice theory is only one piece of the total equation, albeit an important one. I'd like to see what other factors contribute to your final, real-life coil designs. You might also wish to show how you calculate the coil's "pull" (traction). This would be instructive, as well. Would you mind posting these things?
Best Regards,
-e
02/16/2009 6:45 PM
Sorry for the delayed response, but I had to find some time after work to respond!
Yes - greatest dB/dR at the beginning, then the field strength decreases as the turn dia. increases mostly from increase in R per turn and somewhat from reduced field strength from turn farther from center.
Usually when designing a coil, the V is fixed to match the supply voltage available and the I is minimized to perform the work required (proportional to NI=ampere turns). If I is fixed, then yes the V, N & wire size change to provide the most efficient coil. The volume constraints (if any) also contribute, and if not within reason the coil will overheat and melt the insulation on the magnet wire. Once in continuous use, the coil windings will heat up (increases resistance / reduces current & field strength), so the operating temp. environment has to be taken into account.
There is no single simple equation for electromagnetic actuators, so we use a series of developed programs and data to design the coils once the mechanical work profile is determined (force F over distance X) and the coil bobbin size is estimated. The reluctance path of the machanical actuator chosen and the air gap to allow the actuator stroke X can vary so much, it is impractical to cover completely in a simple forum, so I'll just use a simple solenoid with a BH curve (where H=B/3.192x103 NI/in) of a low carbon steel armature as an example.
Attraction force (in lb) F=(B2)a/72 where B=magnetic flux density (kilomaxwells/sq.in)and a=area of attraction (sq.in). Field intensity H=B/3.192x103=NI/X. For the coil to generate this attraction force F then F=(NI/X)2 (a)(1.42x10-7) lb. or NI=X(F/a)1/2 (2.675x103). A starting point for the coil wire diameter dw=(NILav/V)1/2 (x10-3) in where Lav is the average length of a turn. I2R heat generated and the heat dissipation of the structure will generally govern number of turns N (addding turns decreases coil temperature). A typical coil dissipates about 1/2 W/sq. in. of coil outside surface area.
To design a simple cylindrical coil of resistance R=V/I or V2/P (in watts), the volume of the windings (in.3) is Vw= (d02-di2) ∏L/4 where L=length of windings, di=inside dia. of windings and do= maximum desired outside dia. of windings (all in in.). The resistance density of the windings is then Rd=R/Vw From a magnet wire table (or calculate using .73 space factor for typical magnet wire) find Tp turns possible per linear in. of winding space, Np turns possible per sq in. cross section and Rp Ω resistance possible per cu. in. of winding space. Select the wire size with Tp just greater than Rd. The volume of the windings required by this selected wire is Vr=R/Rp. The actual outside diameter of the windings dr=(4Vr/∏L+di2)1/2 and the resultant area of the windings Ar=L(dr-di)/2. The total resulting turns N=NpAr and the resulting ampere turns NI=NrI. (See why we use programs - we usually have to recalculate to dial in the best wire size). Remember, just removing turns to reduce resistance reduces the outside area and raises the continuous operating temperature of the coil. The final operating resistance of the coil Rf=Ro(1=.003859(tf-to)) where .003859 is the temperature coefficient of the wire at original temperature to.
I am not sure this helps, but you asked for it!
Cheers!
02/16/2009 6:52 PM
Well that's dun give us somethin' ter chaw on.
Thanks!
Good Answers: 88
02/17/2009 11:06 AM
Thank you for this excellent post!
02/17/2009 10:54 AM
Now you're thinking StephenD420!
The parasitic series resistance of the coil does increase with more wire length and with the same voltage applied to the coil a smaller current runs through the wire. Less current does mean less magnetism per loop. Some algebra and simple calculus of the equations for resistance per length and the magnetic field should tell you how to optimize wire size and number of turns the magnetic field for current used.
But an additional engineering concern should also be considered. Presumably you will be running this coil in a DC continuous manner. (For the nit pickers out there, the time the coil is turned on will be greater than 5*L/R.) During this time the resistance of the coil will be dissipating heat. I assume you don't want your coil to work only once before it turns into a glowing ember. (Remember your power supply is substantial.) So combining the above calculations with the power equation of P=I2*R one can determine the power dissipated per unit length of the wire making up the coil. This equation will now tell you how to make an efficient magnetic that should last a reasonably long time.
One correction though, the relative permeability of iron (your nail) is 4000 to 5000. So B=μr*μ0*n*I produces a considerably higher field until the nail saturates.
02/16/2009 12:14 AM
Power resistor? I thought a resistor was a resistor. What is a power resistor?
Thanks
Stephen
02/16/2009 1:35 AM
you seem still a student.
02/16/2009 1:46 AM
Any resistor with current flowing through it will dissipate power - in the form of heat.
The power in watts is current x voltage, current2 x resistance, or voltage2 / resistance.
The little things you're probably thinking about, cylindrical with a body about ½" (12mm) long and 1/8" (4mm) diameter can only handle about ½W. If you try to get them to dissipate say 4W, they'll glow red hot for a while, then fry (& rupture, like a fuse).
For handling the higher powers, big chunky ceramic or aluminium bodied wire-wound ones are often used. These latter can be obtained capable of handling 100s of watts, and are usually mounted on a metal heat-sink.
Good Answers: 88
02/16/2009 8:07 AM
"What's in a name? That which we call a roasted resistor by any other name would smell just as bad, if not worse." Bill Shakespeare, Romeo and Juliet Go To Tech School, Act II, Scene II
In other words, it might behoove to use this pièce de résistance, ...
... when our power dissipation would otherwise roast one of these:
02/17/2009 11:21 AM
Did you toast that one 'specially for the photo?
Good Answers: 88
In reply to #65
02/17/2009 12:09 PM
I nuked it in the microwave. You shoulda seen the sparks!
02/17/2009 9:15 PM
wow, thousands of watt can be picked up.
another side, if he would use such resistor, he would not require to wind his winding.
Good Answers: 88
In reply to #71
02/17/2009 11:19 PM
"wow, thousands of watt can be picked up."
Not only, but if I aim it juuuuuust right, I can hear Elvis.
It would actually be very nice in some circumstances if resistors did "pick up" thousands of watts. Unfortunately, they dissipate power. <sigh>
"... if he would use such resistor, he would not require to wind his winding."
You got that right! He could forget that coil altogether and just use the resistor!
02/16/2009 7:02 PM
If you post the nail size (dia + length) and the magnet wire size you have, I can provide the recommented turns required to maximize your field strength without burning up the windings.
02/17/2009 4:07 PM
Stephen
I am the guest who posted #52, 57, & 59 and can easily help you if still needed. If you do not post the nail size by tomorrow (2/18/09), I will presume that you have solved your problem and need no further assistance.
Best Wishes!
In reply to #67
02/17/2009 4:14 PM
But don't you think that Stephen will learn more if he does his own homework?
In reply to #68
02/17/2009 4:32 PM
My intent was to walk him through an example of the formulas I provided to show how it works (if he needs it - I know I needed help the first time). An experienced engineer can easily do it without help, but Steven did not give me that impression (no slight intended). Either way, once he hand winds the wire, I bet he will remember his first run in with E/M forever!
In reply to #69
02/17/2009 4:50 PM
Guest,
I had hoped that my previous comment would spur Stephen to at least attempt to do the math himself first. You may notice that my earlier postings left a trail of equations that should have led Stephen to the equations you fully spelled out in one of your earlier postings. Stephen appears to be both bright and resourceful. Stephen came up with the equation for the magnetic field of a coreless solenoid on his own. I wish to encourage both his curiosity and his own analytical abilities. Offering to do the work before being asked for help seems backwards to me.
Oh, and by the way. Clearly many people sign in with a pseudonym (myself included), so anonymity can be preserved even once registered. Please register.
02/10/2009 8:08 PM
wow, you give out a very simple question, but not very easy to answer satisfactly.
you can either build up your winding by bare wire like you did. or by varnished wire or cotton enamel wire etc. no problem. the mag intensity depends on its size, like length and radus. simple written, = winding x coef x area x length/unit x u.( where u =~ 1 in the air).
as you hear hum, because the current is too hight to afforded by power supply. your doing is right by use a resistor, but it s too large at number, try to reduce it to a suit value.( pay attention to its power). or try to use a regulator power, its about 3v engough.
beside, the large distance the large cureent will be absorbed by winding, try to use a core to incread intensity.
02/12/2009 6:44 AM
For clarification, is your 50 loop electromagnet made from 22 gauge non-insulated copper wire and a small nail.....or are you trying to use the wire and nail to hook the power supply to the electromagnet?
Just a couple ideas that you can test with a multimeter....
1. The power supply may have been damaged by attaching it initially without resistance.
2. If the electromagnet is built using the nail and non insulated wire, the power supply may maintain sufficient voltage that it arcs to the nail and back to the wire, or from winding to winding. If this is occurring and was not occurring with the power supplied via the battery, it could explain the difference in magnetic flux.
3. Perhaps the power supply is AC and not DC? Never hurts to ask/check.
02/12/2009 9:51 AM
Why is nobody blinking at the mention of UN-insulated wire?? If the wire is really UN-insulated, you have a maximum of ONE turn around the core, and your power supply is trying to drive a dead short! Even 50 turns of 22 gage wire is practically a dead short.
The best answer came from europium: get very small (30 gage) magnet wire and put a few HUNDRED turns on it -- you'll get a fine magnet. But know that magnet wire is NOT un-insulated! It's coated with some kind of varnish which provides insulation. The reason for this is that it allows the turns of wire to be very closely packed together (because the layer of insulation is extremely thin), which improves the magnetic flux density by minimizing losses.
These little sayings down here are irritating. -- Me.
02/12/2009 5:19 PM
i blinked.. i definitely blinked. I'm still blinking.
#2 is in direct response to my blinking......
No insulation...leading it to arc to the nail and back or to adjacent loops.
blink blink blink
wink wink
say no more, say no more
Hobbies - Car Customizing - New Member
Good Answers: 11
02/12/2009 9:40 AM
Non insulated sounds like a short circuit to me
Good Answers: 88
02/12/2009 10:07 AM
"Non insulated sounds like a short circuit to me"
Yes, it does, and it would be a short-circuit were the wire non-insulated.
More likely, though, is that the wire is enameled. Why? The OP says, "When I hooked my electromagnet to two D batteries that I tapped together using electrical tape the magnetic field was SOOO much stronger than when I hooked it up to the power supply."
Were the windings shorted, the OP would not get such a strong magnetic field. The problem, then, must be that his power supply simply cannot sustain the kind of load his magnet presents. His magnet windings are not shorted, but simply present a very low impedance to the power supply (I'm guessing that the resistance is around 50 milliohms).
At 24 volts, the OP's supply would have to be able to source a whopping 480 amps to remain in regulation! The OP said his supply is rated at 24 amps, well below this figure. The supply is evidently dropping out of regulation. It simply cannot support the kind of load the OP is presenting.
In summary, the windings are not shorted because his electromagnet actually works, but insofar as his power supply is concerned, the load might as well be a short-circuit!
02/12/2009 9:43 AM
For a: "50 loop electromagnet using 22 gauge non insulated copper wire and a small steel nail" , make sure the turns are all tight together ... coat the entire assembly with a good, thorough coat of "Never-Seez" ... and use 4 automotive-type batteries in series for your power supply.
Make sure you have a video camera rolling, either for AFHV or UTube...
02/12/2009 9:47 AM
awright... Duh! ever hear of MAGNET WIRE...??? <click<<<
Good Answers: 88
02/13/2009 10:04 AM
Yeah? So what's your point?
02/17/2009 9:27 AM
Uh... my *point*...?
even tho the original post stated, quite clearly:
"I am trying to hook a 50 loop electromagnet using 22 gauge non insulated copper wire and a small steel nail"...
YOUR POST , mr guru, (#2) said:
"I'm guessing that you've got around 40" of 22 AWG enameled copper wire in your electromagnet." Which comment led the next few down the wrong trail...!
go reread Post 1, Post 2, Post 3, Post 4 (who at LEAST made mention of the potential problem...), Post 5 (who also took notice)... then you will realize that #6 and #7 were simply trying to turn-up-the-lights so to speak, and (hopefully) elicit some appropriate feedback from Stephen (the originator).
That was all---
02/17/2009 9:43 AM
add a "PS" to the above:
"Drnk coffee! Do stupd thngs faster with mor energi!"
Good Answers: 88
02/17/2009 9:50 AM
That really pushed your button, yes?
LOL
02/12/2009 10:47 AM
Don't know if this has anything to do with this but it appears to me that my cell phone charges much faster when connected to my truck cig.lighter (then when charging on the 120-AC/DC charger). Another interesting item is the report from the inventor Joseph Newman that he can/has demonstrated run an electric 'motor' on (a set of 4 or 6 AA) batteries that have been discharged PRIOR to installation to his 'system'. He tells us that the 'motor' runs on voltage & not on current. Interesting too is that the depleted batteries he stated with will get 'recharged' even though the batteries used are NOT rechargeable (type). Newman also offers an explanation (I'm pretty sure) of what you are experiencing. Good luck. Carlos This (your experience) is telling us that any device meant to harness 'magnetic power' needs to concentrate on the 'conditioned' energy of a DC/battery source. Which brings to mind- if battery chargers were run (taping or using a fully charged battery) as a direct source to/for the depleted battery- it would charge faster- maybe even better (improved molecular & atomic rearrangement)! Somebody try it please.
"The choices you make might be mistakes but it is never too late to turn around." Tony Lang- musician
02/12/2009 1:27 PM
Holy Toledo, this is SUCH a prime example of pseudo-techno-babble-gobbldegook that is so seductive to non-technical people who are infatuated with the notion of energy for free. We fossilized dinosaurs continue to plod along encumbered by the narrow-minded notion that matter and energy can neither be created nor destroyed. It would never occur to a bonehead like me to use a spent AA battery to drive a motor, which would then recharge the spent battery using magnetic power to concentrate the conditioned energy, thereby effecting improved atomic and molecular rearrangement!
Why can't the so-called "scientists" come up with ideas like these?
Good Answers: 88
02/13/2009 9:20 AM
A GA for you, Sir!
"Ladies and Gentlemen, don your tinfoil hats!"
02/12/2009 11:00 AM
StephenD40,
First, Bravo on your honesty about not understanding what's going on.
You have two basic problems in your configuration that can be solved in one simple stroke. But more practically will require two steps. The bare copper wire your using is shorting out to the nail and adjacent turns of the magnet. The power supply you are using can provide 576 watts of power. If you use all of it something will get very hot. (Good intuition about putting the series resistance to stop the shorted electromagnet from shorting out the power supply. But any series resistance will rob power from the electromagnet.) If you obtain some very thin gauge insulated magnet wire you will significantly increase the resistance and prevent inter-turn shorting and increase the number of turns available around your small nail. I expect your best bang for the buck would be to use this wire from Allied http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=214-3590&MPN=8058&R=214-3590&SEARCH=214-3590&DESC=8058?utm_source=Allied&utm_medium=merchandising&amp;utm_campaign=Allied_Top_Sellers&utm_content=214-3590 36 AWG wire has about 0.4 ohms per foot. So if no other series resistance exists (more on this later) ten feet of this wire wrapped around your nail will draw six amps from your twenty four amp capable supply. However, this will mean that your small nail and coil will have to dissipate 144 watts of the available 576 watts of power. Just applying some hand waving thermodynamics, your small nail will have to be water cooled to survive this for any long period of time. I suspect though that the six amps of current with all the turns that ten feet of cable around your small nail will saturate the magnetic permeability of your small nail. So reducing the current to one ampere can now be done by placing a 20 ohm power resistor capable of dissipating 20 watts http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=8954452&MPN=RH05020R00FE02&R=8954452&SEARCH=8954452&DESC=RH05020R00FE02 This will mean that your coil and wire package will now have to dissipate a plausible 4 watts of power. But with 4 watts of power your nail will still get quite hot.
I hope you appreciate this extrapolation of what seems like a simple problem. Knowing the size and composition of the nail along with how much space is available around the nail can permit predicting how much wire can be utilized around your nail. Thus the magnetic field expected at the nail's end can be predicted. Also real thermodynamic analysis can be done to prevent insulation breakdown and/or fire from occurring.
02/12/2009 2:00 PM
Stephen,
maby your power supply is current limited and the coil with out the resistor looks like a short. Also when you have the 2 D cell batterys running the magnet do they heat up? I am thinking its shorting between coils because your using non insulated wire.
have a nice day.
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
02/12/2009 3:42 PM
Hey Stephen,
It sound like you in the process of learning some good stuff! Here is an excellent resource to help you learn some of the background physics involved in what you're doing:
Main page
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
E&M
Solenoid
David A Goodman
02/12/2009 8:08 PM
none pointed out that the winding turns is too little to work for such so higher supply?
why not increase turns up to 5000 to 10000 with more thin coated wire?
02/12/2009 11:03 PM
Your answer reminds me of a joke in an electronics magazine several years ago. A man was building a do-it-yourself kit. The caption at the bottom read "Now wind the secondary - 24,282 turns."
With that many turns he would not get much current, hence not much magnetic field.
02/13/2009 5:17 AM
haha, I cannt make sense of the humor.
how many turns is the primary?
Good Answers: 88
02/13/2009 9:28 AM
"haha, I cannt make sense of the humor."
In a word: ludicrous. Try winding 24,000-odd turns on a coil yourself, by hand. You'd still be at it, fingers blistered and raw and not on this forum posting silly things.
Good Answers: 88
02/13/2009 9:24 AM
"With that many turns he would not get much current, hence not much magnetic field."
Yes, but the author goes on to say, "Now connect the 300 kV supply you built from last month's issue. Wear gloves."
02/13/2009 8:55 PM
3ookv? haha,
I wonder even you that dont remember ampere loop law?
need I mention a simple practice formula? NI= phi x R where R is not resistor, but magnetic resistance. from required magenetic force, we can get I then N,
Good Answers: 88
02/13/2009 10:07 PM
You do realize that the top line is a quote from an earlier post by someone else?
02/15/2009 9:22 PM
It might be a joke. america style amusing?
StandardsGuy shown us a (seemingly) hv vessel for his icon. he might know the way of winding.
02/16/2009 3:46 PM
My present icon is a Thomas 1 ohm resistor which is used as a primary standard in many standards labs. It is a wire wound resistor, but in this case it is not wound for the magnetism, but only to add up the turns to achieve 1 ohm at DC. The little holes are to allow oil to flow through, as it is used in a temperature controlled oil bath. One would absolutely never apply more than 1V to such a device.
Good Answers: 88
02/13/2009 9:48 AM
"none pointed out that the winding turns is too little to work for such so higher supply?"
Why too little? Even a single winding would produce a substantial magnetic field provided you pumped enough current through it and if we ignore the fact that the required current in this case would vaporize a 22 AWG wire.
The OP's 24-volt supply is shutting down. That much is obvious. Funny that his magnet works with two 'D' cells, though. Last time I checked, two 'D' cells in series comes to about three volts. You can be sure, though, that with a load like his the voltage is much, much less when his load is connected. So what is driving the magnet? Current.
Many on this thread seem to think the OP's coil is shorted because he says the wire is "not insulated," whilst completely neglecting the fact that with a functional power source (D-cells in this case), the damn thing actually works. The proof is in the pudding, as they say. And to one not familiar with different types of wire insulation, enameled wire can look as though it were bare.
So what have we here? Which of the OP's observations carries more weight? His speculation that the wire is not insulated, or the hard fact that his electromagnet works?
02/13/2009 10:06 AM
I have a project that requires the production of one Tesla of magnetic field with only eight turns of bare wire sitting in an ultra high vacuum chamber using only the magnetic permeability of free space. Fortunately this field only briefly polarizes a thin film sample for measurement or I'd be sublimating copper over all of the components in the chamber. You can produce enormous magnetic fields with only a few turns of wire, but only briefly.
Good Answers: 88
02/13/2009 11:40 AM
As part of an experiment some years ago I built an electromagnetic nail-gun that would bury a large finishing nail (sans head) about 1-3/4" into a block of wood.
The nail-gun dumped the charge from surplus 300-volt, 60,000 uF capacitor banks (2700 Joules each) into a series of coils that were switched sequentially. Each coil was wound from 80 turns of #4 AWG enameled magnet wire (square cross-section). The coils operated in series pairs that were energized in the sequence: 1-2, 2-3, 3-4, etc.
At the midpoint of each coil pair was a photo-transistor that switched to the next coil in the sequence (using IGBTs) when the tip of the nail broke the beam. Residual current from each de-energized coil was then dumped by a second IGBT to a power resistor in order dissipate the remaining energy from each bank. This prevented inductive spikes and acted to prevent the newly de-energized half of the pair from "pulling back" on the nail once it passed the midpoint.
I used pairs of IGBTs which together functioned as a single SPDT make-before-break switch. Immediately before the first IGBT was switched off the second one connected the resistor to the coil to maintain an unbroken current path. These coils produced some pretty hellish magnetic fields, to be sure - and with relatively few windings.
02/13/2009 1:47 PM
Wow! That nail gun sounds pretty cool! Was there a long charge time before driving the next nail? Did you get tired of having to cut the heads off a box of nails?
(Not recommended for people with pacemakers.)
Would you agree that, theoretically, it could also work with aluminum nails?
Good Answers: 88
02/13/2009 1:52 PM
I haven't given aluminum nails much thought -- although the heads would certainly be easier to snip off (I ground the heads off the steel ones) -- but I did consider using long, cylindrical samarium-cobalt magnets. Talk about moving like a bat outta hell! Sadly, the impact would very likely have shattered them - and they're expensive!
Maybe I should've asked for a DARPA grant, ya?
I wouldn't use aluminum nails because they're not the right shape to make a nice current loop. Better to use aluminum -- or better yet, copper -- rings and launch them from the iron core of an AC coil. You outta try that sometime. Works like gangbusters!
02/13/2009 1:59 PM
Yes, this thing has "weapon" written all over it!
Anyhow, I remember being astounded in college when they demonstrated the effect of the rotating magnetic field, and showed that even an aluminum can would spin like mad in there!
Good Answers: 88
02/13/2009 2:04 PM
Some kinds of motors use a copper disk as the rotor. Aluminum would work as well (being only slightly more resistive) and is probably used where a high-torque, low MOI rotor is needed.
02/13/2009 7:21 PM
I've spent quite a bit of time on & off over the last 30-odd years working on a Gedanken-design for a very similar bit of kit (some of the caps in the surplus shops a few years ago were quite inspiring†).
My intention was to use it to accelerate steel balls (~10mm/½" ø) along a roller-coaster type track - just for fun (or maybe as part of my Master-Clock).
Got any thoughts on the effect of the ball rotating as it passes through the coils? This is one aspect I haven't yet got my head around.
† Have also considered a parallel-charge, series-discharge fly destroyer, among other things.
02/13/2009 1:41 PM
Yes, europium, some of us actually put together that it wasn't really uninsulated wire. I was thinking of going into the whole enameled-wire-looks-like-copper thing, but got too lazy.
Good Answers: 88
02/13/2009 1:46 PM
Ordinarily I'd have been too lazy to broach the subject, as well, but this morning my wife served up some fabulous espresso. A big mouth on speed is not a pleasant sight.
02/13/2009 8:48 PM
ludicrous? fine. learn a fun word. haha.
50 turns winding can has enough air insulation, why you are sure it will be shorted?
it s odd.
he use 3v cells, why dont think the cell soon exhaust after connect with the winding?
if it would be a good power supply, it will be burned as well.
50turns, how much is it resistances? cannt be calculated?
02/16/2009 4:53 PM
Regards
How you made your Electromagnet-Fixture.
Is there no such thing?
All the turns are around <a small steel nail> & you are connecting the ends of wire to Power Supply output?
Your questionis very ambiguous.
50 loops [turns] of uninsulated 22AWG/SWG wire [even if wound carefully not to short-cicuit
will draw enormous current to bring the supply to CL or Clamp the supply almost to few mAs
[If your supply is a professional one. Such supplies go to almost 0V output & very small
current to protect the supply.]
Most of the professional supplies may also have +Crow-Bar-Protection; which shuts down
& does not re-inste unless short-circuit is removed.
Can you give full specs of suuply.
Note:
Magnetizing needs indepth knowledge of Magnetizer /Demagnetizers, otherwise a dangerous mishap may occure.
Very Strong construction of such Fixtures is needed; otherwise @ 24V to 50 turns
[around a loose Fixture may explode it]
Safety is the 1st priority for human life.
02/16/2009 6:04 PM
Haajee, I have to assume that you (like several other posters) have not bothered to read through the thread before throwing in your bit.
I commend your note on safety ("Safety is the 1st priority for human life"), although I thing you were somewhat over-the-top with suggestions of explosions and the need for "indepth knowledge of Magnetizer /Demagnetizers".
Sorry to be blunt, but I consider that the majority of your post was a waste of space.
02/18/2009 9:02 PM
No Comments
Register to Reply 73 comments
Anonymous Poster (13); cnpower (8); DAG (1); Haajee (2); JohnDG (7); redfred (5); rocketsurgeon (5); StandardsGuy (5); StephenD420 (3); user-deleted-13 (23); Yosemit3 (1)
