In our plant we have recentily commissioned a set of Distillation columns.There reboilers are 114 m2.
Condition Column-1(Reboiler)-1 Condition Column-2(Reboiler)-2
1) Vapour loop-600 mm dia Vapour loop-800 mm dia
2) Seperate Ejector
3) Bottom vacuum equalizing line is given for both column.
Problem- When we are operating the column then Column second's Reboiler can't maintain continuous Thermosyphon.Top vacuum continuously showing variation & Reflux rotameter also fluacatuting by 1000 to 1500 kg within 30 second. Then we have shifted bottom overflow position to Reboiler tubesheet hight so that sufficient level maintain for Vapor generation, earlier its position was above tube sheet but there was not significant result.
Please give some positive solution.
Bottom collecting tank is common for two
