Previous in Forum: How to Select C-Channel Size   Next in Forum: PSI at Periphery of Centrifugal Pump Impeller
Lucite Tubing - Burst Pressure to Working Pressure
02/11/2009 9:12 AM
I am about to use a lucite tubing 5.5" OD x 4.5" ID and the vendor has given me
a burt strength sheet. How can go from burst pressure to working pressure.
I need help.
Thanks
Adi
Re: Lucite Tubing - Burst Pressure to Working Pressure
02/11/2009 11:22 AM
If it is not designed to a piping code simply use an appropriate factor of safety.
For example:
  • If the product is non-toxic/corrosive, low temperature/pressure, non-flammable (perhaps water) and the risk of failure and pressure fluctuations is low you may find that dividing the bursting pressure by 1.5 would be an appropriate operating pressure.
  • However, if the product is toxic/flammable/corrosive, and/or the tubing is subjected to thermal/environmental degredation, etc. You may find that you want to divide the bursting pressure by 3 (or more)
Clearly the safety factor is of prime importance and should be selected by great experience and judgement (and again this is if the tubing is not to be designed to a code)
02/11/2009 9:02 PM
well done #1
