Converting to english, I expect you mean you want to know what tool to use to cut GRP tube without damaging the cut or splintering the end when you try to insert a cable?
If that is so, then I think there are a few solutions,
1. you must tape the end before cutting and keep taped till cable is inserted.
2. Pipe Cutter + guide sleeve at opening
3. Water jet cutter
Of course if the GRP is brittle while 3. will give a good end the cable will probably damage it on insertion so, like 2. insert a guide sleeve during the feed process to protect the end
