Current making/breaking capacity is the rating that the contact/switch/breaker etc can close/open at. This means that the component can switch safely whith that amount of current flowing through it. In real life though - you would never rate your equipment for that limit - you would go for the next biggest size.
Assume there is a fault in a line and a breaker is activated.
Then there is a maximum fault current that the breaker can break. If the current is more than that, the breaker can not extinguish the arc between its pole. This is the breaking capacity.
Now Let us say you have tried to close the breaker without clearing the fault. Then there is going to be a fault current as soon as the breaker contacts close. This maximum current is the making capacity of the breaker.
Also there is a possibility that there is another breaker downstream and the fault is beyond that, then you want your breaker to carry a fault current (for some very short time) and let the other breaker trip. This is called short duration capacity.
