I have been working on getting a Thermo 80 series mercury monitor to pass its integrity checks with no luck. The integrity check consist of running the mercury monitor with pure mercury(10ug/l) for the first portion of the test then running mercury and chlorine (10ug/l Hg and 300 l/m Chlorine) the second part. This is supposed to show that the monitor will be able to measure both elemental and oxidized mercury. The monitors are stack mounted on a coal fired boiler running a 350 Mw generator. We have two generating units with a third on the way. The mercury monitor on unit 2 passes its integrity check but the one on the unit 1 will not, they are the same model. The vendor has not been much help. We were supposed to have the channel qualified by the first of the year but need to pass a 3 level integrity check to get it qualified. This is a state requirement due to permiting for our third unit.
Does anyone have experience with Mercury CEMS and if you do have you been abe to get a passing integrity test? How?
Thanks in advance.
